Merci, je pense plutot utiliser le language C, pour programmer.
j'ai trouvé quelque demo qui mon l'air tres simple :
#define BCM2708_PERI_BASE 0x20000000
#define GPIO_BASE (BCM2708_PERI_BASE + 0x200000) /* GPIO controller */
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <sys/mman.h>
#include <unistd.h>
#define PAGE_SIZE (4*1024)
#define BLOCK_SIZE (4*1024)
int mem_fd;
char *gpio_map;
// I/O access
volatile unsigned *gpio;
// GPIO setup macros. Always use INP_GPIO(x) before using OUT_GPIO(x) or SET_GPIO_ALT(x,y)
#define INP_GPIO(g) *(gpio+((g)/10)) &= ~(7<<(((g)%10)*3))
#define OUT_GPIO(g) *(gpio+((g)/10)) |= (1<<(((g)%10)*3))
#define SET_GPIO_ALT(g,a) *(gpio+(((g)/10))) |= (((a)<=3?(a)+4:(a)==4?3:2)<<(((g)%10)*3))
#define GPIO_SET *(gpio+7) // sets bits which are 1 ignores bits which are 0
#define GPIO_CLR *(gpio+10) // clears bits which are 1 ignores bits which are 0
void setup_io();
int main(int argc, char **argv)
int g,rep;
// Set up gpi pointer for direct register access
setup_io();
// Switch GPIO 7..11 to output mode
* You are about to change the GPIO settings of your computer. *
* Mess this up and it will stop working! *
* It might be a good idea to 'sync' before running this program *
* so at least you still have your code changes written to the SD-card! *
// Set GPIO pins 7-11 to output
for (g=7; g<=11; g++)
INP_GPIO(g); // must use INP_GPIO before we can use OUT_GPIO
OUT_GPIO(g);
for (rep=0; rep<10; rep++)
GPIO_SET = 1<<g;
sleep(1);
GPIO_CLR = 1<<g;
sleep(1);
return 0;
} // main
// Set up a memory regions to access GPIO
void setup_io()
/* open /dev/mem */
if ((mem_fd = open("/dev/mem", O_RDWR|O_SYNC) ) < 0) {
printf("can't open /dev/mem \n");
exit(-1);
/* mmap GPIO */
gpio_map = (char *)mmap(
NULL, //Any adddress in our space will do
BLOCK_SIZE, //Map length
PROT_READ|PROT_WRITE,// Enable reading & writting to mapped memory
MAP_SHARED, //Shared with other processes
mem_fd, //File to map
GPIO_BASE //Offset to GPIO peripheral
close(mem_fd); //No need to keep mem_fd open after mmap
if ((long)gpio_map < 0) {
printf("mmap error %d\n", (int)gpio_map);
exit(-1);
// Always use volatile pointer!
gpio = (volatile unsigned *)gpio_map;
} // setup_io
Sauriez vous où je pourrais trouver des capteurs de couleur/ou autre composants
compatible avec le raspberry ? j'ai beau chercher je ne sais pas si le composant
est compatible avec le raspberry.
Merci
