Sat Jan 19, 2013 11:15 am
Bonjour,
merci pour tes conseils. Voici ce que je trouve d'intéressant dans Daemon.log au moment de la coupure du réseau:
Jan 16 23:48:58 raspberrypi ddclient[2091]: SUCCESS: updating xxxxxx.dyndns.org: good: IP address set to xxx.xxx.xxx.x
Jan 18 07:16:15 raspberrypi ifplugd(eth0)[1523]: Link beat lost.
Jan 18 07:16:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 07:16:56 raspberrypi ifplugd(eth0)[1523]: Executing '/etc/ifplugd/ifplugd.action eth0 down'.
Jan 18 07:16:57 raspberrypi ifplugd(eth0)[1523]: Program executed successfully.
Jan 18 07:17:02 raspberrypi ntpd[2065]: Deleting interface #2 eth0, 192.168.1.30#123, interface stats: received=1988, sent=1989, dropped=0, active_time=1784106 secs
Jan 18 07:17:02 raspberrypi ntpd[2065]: 195.13.1.153 interface 192.168.1.30 -> (none)
Jan 18 07:17:02 raspberrypi ntpd[2065]: peers refreshed
Jan 18 07:21:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 07:26:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 07:31:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 07:36:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 07:41:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 07:46:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 07:51:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 07:56:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 08:01:44 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 08:06:45 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 08:11:45 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 08:16:45 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 08:21:45 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 08:26:45 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Jan 18 08:31:45 raspberrypi ddclient[2091]: WARNING: cannot connect to checkip.dyndns.com:80 socket: IO::Socket::INET: Bad hostname 'checkip.dyndns.com'
Etc etc.
Il s'agit de cette ligne qui m'interpelle le plus:
Que s'est-il passé là selon vous?
Merci pour votre aide.
