STICKY: HOWTO: Create Custom HDMI modes
Posted: Mon Jun 01, 2020 3:17 pm
by adadck
Bonjour,
J'ai un problème sur mon raspberry PI4, je n'arrive pas à afficher une résolution 4k sur ma TV. J'ai seulement le choix de 1024x768.
J'ai un TV Samsung 55HU6900, le signal transite par un aplificateur pioneer VSX933.
Les cable HMDI sont en 2.0
Mon config.txt :
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=1
hdmi_mode=97
#hdmi_ignore_edid=0xa5000080
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
J'ai essayé plusieurs configurations, sans succès.
https://photos.app.goo.gl/mvqBWWGGhoDmEqaN8
Merci d'avance pour votre aide.
