Merci.
Alors j'ai enfin eu le temps de regarder et si je compare le début de mon démarrage, ça donne :
, ça commence par le kernel hélas.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.97-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:21:14 GMT 2020
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[ 0.000000] On node 0 totalpages: 504832
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 308224 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
[ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 503104
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:1360x768M@60,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 smsc95xx.macaddr=XXXXXXXXXXXXX vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1721804K/2019328K available (8192K kernel code, 687K rwdata, 2408K rodata, 2048K init, 850K bss, 35380K reserved, 262144K cma-reserved, 1232896K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 688 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 851 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 28692 entries in 85 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000018] Switching to timer-based delay loop, resolution 18ns
[ 0.000245] Console: colour dummy device 80x30
[ 0.000270] console [tty1] enabled
[ 0.000315] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000331] pid_max: default: 32768 minimum: 301
[ 0.000607] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000625] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001406] CPU: Testing write buffer coherency: ok
[ 0.001829] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002489] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002649] rcu: Hierarchical SRCU implementation.
[ 0.003523] smp: Bringing up secondary CPUs ...
[ 0.004354] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005302] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006214] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006351] smp: Brought up 1 node, 4 CPUs
[ 0.006365] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006374] CPU: All CPU(s) started in HYP mode.
[ 0.006383] CPU: Virtualization extensions available.
[ 0.007201] devtmpfs: initialized
[ 0.017619] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.017830] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017851] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.025388] pinctrl core: initialized pinctrl subsystem
[ 0.026269] NET: Registered protocol family 16
[ 0.029326] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.030857] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.030868] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.031077] Serial: AMBA PL011 UART driver
[ 0.034173] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.050045] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-02-12 12:36, variant start
[ 0.060059] raspberrypi-firmware soc:firmware: Firmware hash is c3c8dbdf147686fb0c3f32aece709d0653368810
[ 0.103141] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.106370] vgaarb: loaded
[ 0.106728] SCSI subsystem initialized
[ 0.106932] usbcore: registered new interface driver usbfs
[ 0.106986] usbcore: registered new interface driver hub
[ 0.107056] usbcore: registered new device driver usb
[ 0.108382] clocksource: Switched to clocksource arch_sys_counter
[ 0.187450] VFS: Disk quotas dquot_6.6.0
[ 0.187537] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.187681] FS-Cache: Loaded
[ 0.187865] CacheFiles: Loaded
[ 0.188484] simple-framebuffer 3e7fe000.framebuffer: framebuffer at 0x3e7fe000, 0x3fc000 bytes, mapped to 0x(ptrval)
[ 0.188499] simple-framebuffer 3e7fe000.framebuffer: format=a8r8g8b8, mode=1360x768x32, linelength=5440
[ 0.194150] Console: switching to colour frame buffer device 170x48
[ 0.199127] simple-framebuffer 3e7fe000.framebuffer: fb0: simplefb registered!
[ 0.208416] NET: Registered protocol family 2
[ 0.209097] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.209123] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.209195] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.209267] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.209394] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209424] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209641] NET: Registered protocol family 1
[ 0.210231] RPC: Registered named UNIX socket transport module.
[ 0.210242] RPC: Registered udp transport module.
[ 0.210252] RPC: Registered tcp transport module.
[ 0.210261] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.210277] PCI: CLS 0 bytes, default 64
[ 0.213412] Initialise system trusted keyrings
[ 0.213584] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.222653] FS-Cache: Netfs 'nfs' registered for caching
[ 0.223196] NFS: Registering the id_resolver key type
[ 0.223219] Key type id_resolver registered
[ 0.223229] Key type id_legacy registered
[ 0.223249] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.225538] Key type asymmetric registered
[ 0.225549] Asymmetric key parser 'x509' registered
[ 0.225660] bounce: pool size: 64 pages
[ 0.225702] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.225878] io scheduler noop registered
[ 0.225889] io scheduler deadline registered (default)
[ 0.226047] io scheduler cfq registered
[ 0.226058] io scheduler mq-deadline registered (default)
[ 0.226069] io scheduler kyber registered
[ 0.229283] brcm-pcie fd500000.pcie: could not get clock
[ 0.229340] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.229376] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ 0.288414] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.288661] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.288677] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.288694] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.288737] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.288877] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.291576] PCI: bus0: Fast back to back transfers disabled
[ 0.291593] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.291808] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.291933] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.292252] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.294985] PCI: bus1: Fast back to back transfers disabled
[ 0.295001] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.295050] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.295070] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.295141] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.295158] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.295367] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.295534] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[ 0.295689] pcieport 0000:00:00.0: AER enabled with IRQ 53
[ 0.295855] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.299961] iproc-rng200 fe104000.rng: hwrng registered
[ 0.300180] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.300689] vc-sm: Videocore shared memory driver
[ 0.301079] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.311411] brd: module loaded
[ 0.321217] loop: module loaded
[ 0.321963] Loading iSCSI transport class v2.0-870.
[ 0.323659] libphy: Fixed MDIO Bus: probed
[ 0.324096] bcmgenet fd580000.genet: failed to get enet clock
[ 0.324114] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.324131] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.324148] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.324170] bcmgenet: Skipping UMAC reset
[ 0.324405] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.338419] libphy: bcmgenet MII bus: probed
[ 0.378935] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.379866] usbcore: registered new interface driver r8152
[ 0.379933] usbcore: registered new interface driver lan78xx
[ 0.379987] usbcore: registered new interface driver smsc95xx
[ 0.380291] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.380323] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.382179] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.382500] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[ 0.383320] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.383335] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.383348] usb usb1: Product: xHCI Host Controller
[ 0.383359] usb usb1: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
[ 0.383370] usb usb1: SerialNumber: 0000:01:00.0
[ 0.383887] hub 1-0:1.0: USB hub found
[ 0.383968] hub 1-0:1.0: 1 port detected
[ 0.384436] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.384459] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.384478] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.384837] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.384851] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.384862] usb usb2: Product: xHCI Host Controller
[ 0.384874] usb usb2: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
[ 0.384884] usb usb2: SerialNumber: 0000:01:00.0
[ 0.385378] hub 2-0:1.0: USB hub found
[ 0.385458] hub 2-0:1.0: 4 ports detected
[ 0.386680] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.386872] dwc_otg: FIQ enabled
[ 0.386881] dwc_otg: NAK holdoff enabled
[ 0.386890] dwc_otg: FIQ split-transaction FSM enabled
[ 0.386902] Module dwc_common_port init
[ 0.387114] usbcore: registered new interface driver uas
[ 0.387206] usbcore: registered new interface driver usb-storage
[ 0.387380] mousedev: PS/2 mouse device common for all mice
[ 0.388586] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.390038] sdhci: Secure Digital Host Controller Interface driver
[ 0.390048] sdhci: Copyright(c) Pierre Ossman
[ 0.390449] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.390838] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.393871] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.394024] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.394154] usbcore: registered new interface driver usbhid
[ 0.394163] usbhid: USB HID core driver
[ 0.394937] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.396740] [vc_sm_connected_init]: start
[ 0.406294] [vc_sm_connected_init]: end - returning 0
[ 0.407465] Initializing XFRM netlink socket
[ 0.407494] NET: Registered protocol family 17
[ 0.407592] Key type dns_resolver registered
[ 0.407936] Registering SWP/SWPB emulation handler
[ 0.408590] registered taskstats version 1
[ 0.408607] Loading compiled-in X.509 certificates
[ 0.415686] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.415751] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.420962] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.421512] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.422148] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.422160] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.448224] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
[ 0.448311] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
[ 0.465503] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.467109] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.468725] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.471601] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.473204] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.478416] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.480811] of_cfs_init
[ 0.480978] of_cfs_init: OK
[ 0.481701] Waiting for root device /dev/mmcblk0p7...
[ 0.526606] random: fast init done
[ 0.575202] mmc0: new ultra high speed DDR50 SDHC card at address 0007
[ 0.578505] mmcblk0: mmc0:0007 SD32G 29.0 GiB
[ 0.580704] mmc1: new high speed SDIO card at address 0001
[ 0.583692] mmcblk0: p1 p2 < p5 p6 p7 p8 p9 >
[ 0.607774] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 0.607819] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 0.612549] devtmpfs: mounted
[ 0.620293] Freeing unused kernel memory: 2048K
[ 0.638639] Run /sbin/init as init process
[ 0.748440] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.931107] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 0.931122] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.931134] usb 1-1: Product: USB2.0 Hub
[ 0.933305] hub 1-1:1.0: USB hub found
[ 0.933636] hub 1-1:1.0: 4 ports detected
[ 1.026531] systemd[1]: System time before build time, advancing clock.
[ 1.107580] NET: Registered protocol family 10
[ 1.108905] Segment Routing with IPv6
[ 1.149637] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.150333] systemd[1]: Detected architecture arm.
[ 1.158279] systemd[1]: Set hostname to <XXXXXXXXXXX>.
[ 1.160904] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 1.258536] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[ 1.418351] usb 1-1.4: New USB device found, idVendor=248a, idProduct=8367, bcdDevice= 1.00
[ 1.418406] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.418420] usb 1-1.4: Product: Wireless Receiver
[ 1.418432] usb 1-1.4: Manufacturer: Telink
[ 1.434339] input: Telink Wireless Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:248A:8367.0001/input/input0
[ 1.434704] input: Telink Wireless Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:248A:8367.0001/input/input1
[ 1.498610] input: Telink Wireless Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:248A:8367.0001/input/input2
[ 1.498782] hid-generic 0003:248A:8367.0001: input,hidraw0: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-0000:01:00.0-1.4/input0
[ 1.506292] input: Telink Wireless Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:248A:8367.0002/input/input3
[ 1.569064] hid-generic 0003:248A:8367.0002: input,hidraw1: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-0000:01:00.0-1.4/input1
[ 1.762325] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.771063] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.776457] systemd[1]: Created slice system-getty.slice.
[ 1.776808] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.777375] systemd[1]: Listening on udev Control Socket.
[ 1.782606] systemd[1]: Listening on Syslog Socket.
[ 1.803307] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 1.803805] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.804457] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.902206] i2c /dev entries driver
[ 2.255800] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 2.397582] systemd-journald[104]: Received request to flush runtime journal from PID 1
[ 2.912997] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 2.913509] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 2.913990] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 2.914462] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 2.963109] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 2.965183] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 2.965199] [vc_sm_connected_init]: start
[ 2.967568] media: Linux media interface: v0.10
[ 2.967629] [vc_sm_connected_init]: installed successfully
[ 2.993120] videodev: Linux video capture interface: v2.00
[ 3.018607] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.018754] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.037614] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.072034] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.093352] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 3.093392] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 3.100619] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 3.100659] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 3.102245] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.110095] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 3.110129] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 3.152232] bcm2835_audio soc:audio: card created with 8 channels
[ 3.233213] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.402234] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.484415] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 3.497819] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 3.498774] usbcore: registered new interface driver brcmfmac
[ 3.648707] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 3.667932] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 3.667950] checking generic (3e7fe000 3fc000) vs hw (0 ffffffffffffffff)
[ 3.667960] fb: switching to vc4drmfb from simple
[ 3.668209] Console: switching to colour dummy device 80x30
[ 3.671182] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 3.671196] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.671205] [drm] No driver support for vblank timestamp query.
[ 3.671215] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 3.718872] Console: switching to colour frame buffer device 170x48
[ 3.718912] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[ 3.762464] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 3.775881] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 6.326336] random: crng init done
[ 6.326352] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.359816] uart-pl011 fe201000.serial: no DMA platform data
[ 6.536810] 8021q: 802.1Q VLAN Support v1.8
[ 6.720271] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 6.953525] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.953544] brcmfmac: power management disabled
[ 7.300114] bcmgenet: Skipping UMAC reset
[ 7.399178] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 7.399523] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.408481] bcmgenet fd580000.genet eth0: Link is Down
[ 10.488572] bcmgenet fd580000.genet eth0: Link is Up - 100Mbps/Full - flow control off
[ 10.488601] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.620763] fuse init (API version 7.27)
[ 12.093170] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[ 13.131464] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 13.224298] Bluetooth: Core ver 2.22
[ 13.224344] NET: Registered protocol family 31
[ 13.224348] Bluetooth: HCI device and connection manager initialized
[ 13.224359] Bluetooth: HCI socket layer initialized
[ 13.224367] Bluetooth: L2CAP socket layer initialized
[ 13.224387] Bluetooth: SCO socket layer initialized
[ 13.232366] Bluetooth: HCI UART driver ver 2.3
[ 13.232376] Bluetooth: HCI UART protocol H4 registered
[ 13.232422] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.232541] Bluetooth: HCI UART protocol Broadcom registered
[ 13.507164] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.507173] Bluetooth: BNEP filters: protocol multicast
[ 13.507187] Bluetooth: BNEP socket layer initialized
[ 13.546866] Bluetooth: RFCOMM TTY layer initialized
[ 13.546887] Bluetooth: RFCOMM socket layer initialized
[ 13.546902] Bluetooth: RFCOMM ver 1.11
[ 13.571695] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
