Bonjour
Apres avoir perdue le pass du Raspberry quand je me connecte avec mo Mac via Terminal j'ai
Last login: Sun Apr 12 16:09:25 on ttys000
MacBook-Pro-de-jha:~ jha03500$ ssh pi@raspberrypi.local
@ WARNING: POSSIBLE DNS SPOOFING DETECTED! @
The ECDSA host key for raspberrypi.local has changed,
and the key for the corresponding IP address 2a01:e0a:279:52f0:8221:74f8:addb:4a56
is unknown. This could either mean that
DNS SPOOFING is happening or the IP address for the host
and its host key have changed at the same time.
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:iH+moQYJbdM6V0QQza2mYY8E38fr3nOu8RKSiNBqhgc.
Please contact your system administrator.
Add correct host key in /Users/jha03500/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /Users/jha03500/.ssh/known_hosts:1
ECDSA host key for raspberrypi.local has changed and you have requested strict checking.
Host key verification failed.
Avez vous une solution ?
Merci
