czioriri
Probléme driver Wireless Network Adapter Ralink MT7601U
Fri Aug 03, 2018 7:46 am
Bonjour
J'ai un Raspberry Pi rev B Linux 4.14.50+ # 1122 mar Jun 19 12:21:21 BST 2018 GNU / Linux armv6l et un dongle wifi Bus 001 Device 004: 148f ID: 7601 Ralink Technology, Corp. MT7601U Wireless Adapter
Il ne marche pas, je pense que s'est un problème de driver.
J'ai essayé https://github.com/kuba-moo/mt7601u/issues/64
Download corresponding kernel source from kernel.org. For example: if you have 4.4.0-104-generic download version 4.4.
From archive unpack just folder drivers/net/wireless/mediatek/mt7601u
Edit phy.c. Find function mt7601u_init_cal and comment out call mt7601u_mcu_calibrate(dev, MCU_CAL_RXIQ, 0); like so:
// ret = mt7601u_mcu_calibrate(dev, MCU_CAL_RXIQ, 0);
// if (ret)
// return ret;
// ret = mt7601u_mcu_calibrate(dev, MCU_CAL_DPD, dev->dpd_temp);
// if (ret)
// return ret;
Find function mt7601u_phy_recalibrate_after_assoc and comment out call mt7601u_mcu_calibrate(dev, MCU_CAL_DPD, dev->curr_temp); like so:
void mt7601u_phy_recalibrate_after_assoc(struct mt7601u_dev *dev)
// mt7601u_mcu_calibrate(dev, MCU_CAL_DPD, dev->curr_temp);
mt7601u_rxdc_cal(dev);
Build module: make -C /lib/modules/$(uname -r)/build M=$(pwd) modules
Remove device
sudo rmmod mt7601u
sudo insmod ./mt7601u.ko
Insert device
Check there are no errors in dmesg and interface appeared in ip link, check connection stability.
To make change persistent till next kernel upgrade: backup original module and replace with compiled. To find out where is original module run modinfo mt7601u (view string filename: /lib/modules/_KERNEL_VERSION_/kernel/drivers/net/wireless/mediatek/mt7601u/mt7601u.ko).
Je suis bloqué le makefile quel module introduire ?? dans quel répertoire exécuter le Makefile?
HELP
Merci
j'ai eu un AVC ! je ne écris pas bien :oops: !!
had a stroke! I do not write well: :oops: : !!
totoharibo
Re: Probléme driver Wireless Network Adapter Ralink MT7601U
Fri Aug 03, 2018 7:57 am
petite voie plus simple à tenter :
sudo su #pour être root et être propre
apt-get update
apt-get upgrade
apt-cache show firmware-ralink|grep 7601 #pour voir que le driver existe
apt-get install firmware-ralink #pour le charger
et relancer le WiFi pour voir
pourquoi compiler d'office ?
regarder d'abord ce que les paquets de la distrib offrent : plein de choses insoupçonnées :lol:
czioriri
Fri Aug 03, 2018 1:57 pm
J'ai çà
sudo apt-get install firmware-ralink
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Note : sélection de « firmware-misc-nonfree » au lieu de « firmware-ralink »
firmware-misc-nonfree is already the newest version (1:20161130-3+rpt3).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
piuis
sudo apt-cache show firmware-ralink|grep 7601
ou
N: Impossible de choisir les versions du paquet « firmware-ralink » qui n'est qu'un paquet virtuel
N: Aucun paquet n'a été trouvé
Pas de trace driver Wireless Network Adapter Ralink MT7601U
Je pensai faire https://github.com/kuba-moo/mt7601u/issues/64 ???!!!
Mais le makefile m'a bloquè
Tu as une autre solutoin !!!
Merci
totoharibo
Fri Aug 03, 2018 8:55 pm
si tu enlèves le "firmware-misc-nonfree" (apt-get purge ...)
et que tu mets firmware-ralink ?
chez moi (OK c'est pas la dernière mouture de Raspbian) :
[email protected]:~ $ apt-cache show firmware-ralink
Package: firmware-ralink
Source: firmware-nonfree
Version: 1:0.43+rpi6
Architecture: all
Maintainer: Debian Kernel Team <[email protected]>
Installed-Size: 145
Suggests: initramfs-tools
Multi-Arch: foreign
Homepage: http://git.kernel.org/?p=linux/kernel/g ... rmware.git
Priority: optional
Section: non-free/kernel
Filename: pool/main/f/firmware-nonfree/firmware-ralink_0.43+rpi6_all.deb
SHA256: 07477f119143b015813ea9282f55df3163ae40afd959e409698d2b350b6c3886
SHA1: c0d3697506c5c104a3835ff754e5830e8f5b4a04
MD5sum: bd5c7378533c7c35e5fe530366e6418a
Description: Binary firmware for Ralink wireless cards
This package contains the binary firmware for wireless network cards with
the Ralink RT2501 [Turbo], RT2600, RT5201 [Turbo], RT5600, RT5201USB,
RT2800P[D], RT2700P[D], RT2700E[D], RT2800E[D], RT2800U[D] or RT3000E[D]
chipsets or RT3070/RT3071/RT3072 chips, supported by the rt61/rt61pci,
rt73/rt73usb, rt2860sta, rt2870sta/rt2870, rt3070sta or rt3090sta drivers.
...etc...
czioriri
Mon Aug 06, 2018 8:19 am
J'ai tentè çà
[email protected]:~ $ sudo apt-get remove firmware-misc-nonfree
Les paquets suivants seront ENLEVÉS :
0 mis à jour, 0 nouvellement installés, 1 à enlever et 0 non mis à jour.
Après cette opération, 8.155 ko d'espace disque seront libérés.
Souhaitez-vous continuer ? [O/n] o
(Lecture de la base de données... 126529 fichiers et répertoires déjà installés.)
Suppression de firmware-misc-nonfree (1:20161130-3+rpt3) ...
[email protected]:~ $ sudo apt-get install firmware-ralink
Les NOUVEAUX paquets suivants seront installés :
0 mis à jour, 1 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 2.322 ko dans les archives.
Après cette opération, 8.155 ko d'espace disque supplémentaires seront utilisés.
Réception de:1 http://archive.raspberrypi.org/debian stretch/main armhf firmware-misc-nonfree all 1:20161130-3+rpt3 [2.322 kB]
2.322 ko réceptionnés en 1s (1.462 ko/s)
Sélection du paquet firmware-misc-nonfree précédemment désélectionné.
(Lecture de la base de données... 126276 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de .../firmware-misc-nonfree_1%3a20161130-3+rpt3_all.deb ...
Dépaquetage de firmware-misc-nonfree (1:20161130-3+rpt3) ...
Paramétrage de firmware-misc-nonfree (1:20161130-3+rpt3) ...
update-initramfs: deferring update (trigger activated)
Traitement des actions différées (« triggers ») pour initramfs-tools (0.130) ...
p
Mais il ne choix  firmware-misc-nonfree
Merci
totoharibo
Mon Aug 06, 2018 7:52 pm
ben on ne doit pas avoir la même version de Raspbian : moi c'est installé depuis longtemps out of the boxr et ne n'en ai pas besoin : je suis sur RPi3 :lol:
mes recherches dans le désordre :
tenter de trouver le driver dans les paquets :
- charge le paquet apt-file
- il faut mettre à jour la base de données des packages (apt-file update je crois)
- ensuite chercher le fichier : apt-file find mt7601u
chez moi le fichier est dans /lib/firmware.
un petit tour par là :
https://packages.debian.org/wheezy/all/ ... k/download
un paquet tout chaud à installer par dpkg -i
sinon vu cela dans le github :
>>MT7601U Linux driver
>>Note: Kernel 4.2 has been released which contains a driver for mt7601u, this repository is now deprecated.
question con : tu es sur Raspbian ?
totoharibo
Thu Aug 09, 2018 11:57 am
j''en rajoute une couche : regardé sur un autre RPi (recopié de l'écran du RPi) :
$ cat /proc/version
Linux version 4.14 ...
$ apt-cache search firmware-misc-nonfree|grep 7601
/lib/firmware/mt7601u.bin
ça donne quoi chez toi ?
czioriri
Thu Aug 09, 2018 1:27 pm
Salut
cat /proc/version
Linux version 4.14.58+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1130 Thu Jul 26 14:23:59 BST 2018
Rien comme driver
mais je fais un
cd /lib/firmware/
ls -la|grep mt7601u
-rw-r--r-- 1 root root 45412 mar 12 12:08 mt7601u.bin
il est là !!!
mais le dongle wifi n'est pas actif
lsusb
Bus 001 Device 005: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 041: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
Pourquoi ??
Return to “Français”
