Djonn
TriggerHappy Daemon (THD) doesn't work on my Pi running Retropie ! Help
Tue Jun 12, 2018 5:04 pm
I followed multiple tutorial to set up triggerhappy but nothing happen... I mostly use this one (go directly to the triggerhappy section).
So installed triggerhappy: sudo apt-get install triggerhappy When I do and press the key I want to use: thd --dump /dev/input/event* I got:
EV_KEY BTN_BASE6 1 /dev/input/event4
# BTN_BASE6 1 command
EV_KEY BTN_BASE6 0 /dev/input/event4
# BTN_BASE6 0 command
Finally I did: pi@retropie:~ $ sudo nano /etc/triggerhappy/triggers.d/testb.conf and write inside: BTN_BASE6 1 sudo chmod 777 /sys/class/backlight/rpi_backlight/brightness && echo 25 > /sys/class/backlight/rpi_backlight/brightness ( the script sudo chmod 777... is useful to control the brightness of the Pi screen, and it works great when I type it in the terminal via SSH).
And restart triggerhappy : sudo service triggerhappy restart
I guess i do something wrong...
totoharibo
Re: TriggerHappy Daemon (THD) doesn't work on my Pi running Retropie ! Help
Wed Jun 13, 2018 8:52 am
on voit que tu es nouveau et que n'as même pas lu un post de ce forum :cry:
Ici on parle français (eh oui ça existe encore).
pour info un grand carré avec écrit "search the forums via Duckduckgo"
Tapes triggerhappy dedans tu ne dois pas être le premier et fais le tri.
Fais gaffe tu auras sans doute des réponses en patois local :lol:
Ensuite à ton service et on pourra causer si besoin.
Return to “Français”
Who is online
