Lamusicadomi
Camera Entrée
Fri Jun 01, 2018 10:06 am
Bonjour à tous,
J'ai d'un côté un raspberry PI Zéro et de l'autre une Caméra positionnée sur ma porte d'entrée.
Je voudrais utiliser le raspberry pour visualiser ma caméra de l'intérieur de l'entrée.
Quel matériel faut-il et quel applicatif ?
Merci d'avance pour votre aide.
A bientôt ! ;)
HermannSW
Re: Camera Entrée
Fri Jun 01, 2018 10:40 pm
Ich könnte jetzt auf Deutsch antwortent,
because I don't speak French, but that would help nobody.
From Google translate it seems that you want to visualize the entrance with a camera, but you don't say which kind of a camera.
With a Raspberry camera you can use "raspistill -t 0" or "raspivid -t 0" and you will see preview on HDMI monitor connected to Pi Zero.
If you want something to happen automatically on activity at entrance, software like "motion" can do that for you.
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/fork-raspiraw
https://github.com/Hermann-SW/userland
https://twitter.com/HermannSW
Lamusicadomi
Re: Camera Entrée
Sat Jun 02, 2018 9:57 am
Thank you very much for your help and sorry if i posted my demand in French... ;)
I'm going to try your ideas and come back eventually to you if i have a problem. :!:
Another time, thank you !
Best regards
Lamusicadomi
marsokod
Re: Camera Entrée
Sat Jun 02, 2018 1:00 pm
If you want to build a monitoring camera, have a look at MotionEyeOS which is a distribution dedicated to that: https://github.com/ccrisan/motioneyeos
Lamusicadomi
Re: Camera Entrée
Sat Jun 02, 2018 3:19 pm
Is there more simply ?
MotionEyeOS delete my OS actual ?
I have a Raspberry pi zero
I installed motion but my camera is on a different adress than my Raspberry...
For exemple :
Raspberry is 192.16.1.20 and my camera is 192.168.1.21...
Furthemore i have a user name and password to access at the camera.
How can i do ?
Thanks you by advance for your help.
Best regards
nikotinux
Re: Camera Entrée
Sat Jun 02, 2018 5:27 pm
si c'est une camera IP essaye VLC
Lamusicadomi
Re: Camera Entrée
Sat Jun 02, 2018 7:50 pm
I tried with VLC and it's OK but i can't control the picture's size and the timing...
Do you have a solution ?
Lamusicadomi
totoharibo
Re: Camera Entrée
Mon Jun 04, 2018 6:39 am
pas de possibilité de réglage de la caméra IP ?
Ça doit être possible avec un butineur sur un autre port à la même adresse IP .
Regarde la doc technique de ta caméra.
Return to “Français”
