justinbeaird
raspberry pi 2 microSDXC card?
Tue Feb 10, 2015 5:37 pm
will microSDXC cards work with raspberry pi 2?
i am thinking of buying Team 64GB microSDXC Flash Card Model TUSDX64GUHS03
mimi123
Re: raspberry pi 2 microSDXC card?
Tue Feb 10, 2015 5:41 pm
Should work. (128GB SD cards worked on the B+ with a SD -> microSD adapter)
Tue Feb 10, 2015 7:03 pm
It needs special handling to get NOOBS copied on to a 64GB card.
Also be extremely careful about buying a genuine card, 64GB is the common capacity for the fake cards from China.
This is a doctor free zone.
justinbeaird
Tue Feb 10, 2015 8:42 pm
DougieLawson wrote:It needs special handling to get NOOBS copied on to a 64GB card.
Special handling will win32disk imager work?
mimi123
Tue Feb 10, 2015 8:45 pm
Yes
Tue Feb 10, 2015 9:38 pm
Win32DiskImager can't used for NOOBS. Getting NOOBS on a card is a simple unzip job. The NOOBS/64GB problem is that you have to reformat the first primary partition as FAT32 before unzipping NOOBS on to it.
If you stick a Raspbian.img file on a 64GB card with the imager you won't have any troubles.
LaKraven
Tue Feb 10, 2015 11:07 pm
Create the partition & format the card using EaseUS Partition Master. When creating the Partition, select "FAT32", and make sure it is a "Primary" partition and not set to "Logical".
It also seems to make some difference when you tick the "Optimize for SSD" (which I recommend ticking).
That's all you have to do, and the card (regardless of capacity) will be ready for use in your RPi2.
I'm running both 64GB and 128GB MicroSDXC in mine.
