Case for Raspberry 2
Posted: Sun Feb 08, 2015 4:14 pm
by javin10
Someone knows if the case for Raspberry B+ is compatible for Raspberry 2 B?
Re: Case for Raspberry 2
Posted: Sun Feb 08, 2015 4:19 pm
by jbeale
Almost all of the B+ cases work for Rpi 2. However the cpu (SOC) did move slightly.
Posted: Sun Feb 08, 2015 4:20 pm
by mikerr
The vast majority cases will fit (external dimension are identical to the B+)
with the exception of the older pibow coupe :
http://shop.pimoroni.com/products/pibow-coupe
Posted: Sun Feb 08, 2015 4:33 pm
by gordon77
Posted: Sun Feb 08, 2015 4:42 pm
by pluggy
The cheap ones made from laser cut perspex for the B+ fit fine.
http://www.ebay.co.uk/itm/331356449543? ... EBIDX%3AIT
This is one I bought a while back, the vendor has updated it to include the Pi2 in the listing now (and put the price up from £2.95 to £4.95 :( ).
Posted: Sun Feb 08, 2015 6:23 pm
by Nightwing2012
Was surprised that Frys (U.S.) Have a Hammond case that fits the 2 nice. Repackage under Velleman and list only B+. Ugly as sin. Slot opening on bottom near memory. Expensive at $12.
But will do for now. ^_^
Posted: Mon Feb 09, 2015 10:16 pm
by metalj
Could someone recommend me a good case for the pi2 that blocks the camera flash bug and protects against dust?
Posted: Tue Feb 10, 2015 12:25 am
by DougieLawson
Posted: Tue Feb 10, 2015 1:05 am
by rpiswag
Go with one of these from Adafruit they come in different colors. With the lid and base only cost $8. Here is the link http://www.adafruit.com/product/2285.
Posted: Tue Feb 10, 2015 5:27 am
by allfox
Greetings,
I am planing on building a hand-made pi 2 case either. I worried paper could burn so I'm thinking about metal can or plastic cola bottle.
I dont' know how to cut metal can, what kind of tool could help me?
Plastic could melt, I'm going to put some boiled water into it to try. Not so sure if it works.
Posted: Tue Feb 10, 2015 6:53 am
by BMS Doug
allfox wrote:
Greetings,
Paper or card are fine unless you are exposing the case to a naked flame (which would be bad for plastic too).
Metal or any other conductive material would be a bad idea for a case unless you ensure that the bottom of the pi doesn't touch the case.
Tin snips (which look like very heavy duty scissors) are the standard tool for cutting thin metal like cans.
Plastic bottles will melt at a temperature between 130 to 210 degrees centigrade. Hot glue guns will stick it together.
Posted: Tue Feb 10, 2015 12:39 pm
by allfox
BMS Doug wrote: ......
I forgot one of the basic purposes of a case: protect Pi from short cut.
Thanks for information.
Posted: Tue Feb 10, 2015 1:18 pm
by BMS Doug
allfox wrote: I forgot one of the basic purposes of a case: protect Pi from short circuit.
FTFY.
Honestly, cardboard is fine, There are designs for printing a case on card.
Posted: Tue Feb 10, 2015 2:25 pm
by zproc
gordon77 wrote:I got one from amazon, its needs a slight modification
http://www.amazon.co.uk/dp/B00M8ZEHIQ/r ... ds=Pi+case
https://www.youtube.com/watch?v=XlBN0YmZWr4
I had ordered the same one on the day of the Pi 2 launch (i had only B models, not any B+) and before i received it i put some heatsinks on the Pi 2... and well, this case has a 'slot' for the Broadcom chip and the Pi 2 one is not at the same place, so i can't put the second part of the case on it because of the Broadcom heatsink.
Just to warn people...
