simpex
Weird: If you take a photo of Raspberry Pi 2 it crashes!!
Sun Feb 08, 2015 9:32 am
"Early customers of the Raspberry Pi 2 have been testing it out - and they've found a pretty strange problem with it.
It turns out that if you try and take a photo of the Raspberry Pi 2 using a certain type of camera, it crashes and turns off.
What's going on here is pretty weird. Any cameras with a Xenon flash trigger a reaction in a chip on the Raspberry Pi. One of the chips on the exposed computer's circuit board seems to be sensitive to light and poorly shielded, so when the camera's flash triggers, it causes the entire device to crash."
Source: http://www.businessinsider.com/raspberr ... off-2015-2
Video: https://www.youtube.com/watch?v=wyptwlzRqaI
PeterO
Re: Weird: If you take a photo of Raspberry Pi 2 it crashes!
Sun Feb 08, 2015 9:37 am
Clueless press jump on a "non-problem" and blow it out of all proportion....
PeterO
r3d4
Sun Feb 08, 2015 9:39 am
Your post made it to hacker news https://news.ycombinator.com/item?id=9015663 :roll:
PeterO
Sun Feb 08, 2015 9:41 am
r3d4 wrote:Your post made it to hacker news https://news.ycombinator.com/item?id=9015663 :roll:
Gee there's a lot of rubbish posted on that board !
PeterO
mikerr
Sun Feb 08, 2015 9:42 am
We've come full circle
First found here on this forum
news males it on twitter, youtube , news sites
Reported back on here
Took 12 hrs :)
At least they mention the simple fix of covering a single component (u16),
a case probably prevents it too
simpex
Sun Feb 08, 2015 10:16 am
Does Raspberry Pi 2 crashes, freeze or turns off in bright Sun? From what I have read till now a Xenon Flash and Laser Pointer induces glitches causing the board to malfunction. Normally the strong light of the Sun should do the same.
mikerr
Sun Feb 08, 2015 10:18 am
In England we don't get much sun to test :)
EtonMess
Sun Feb 08, 2015 10:21 am
You mean that a Pi wouldn't remain stable through the EMP caused by a nuclear explosion?
Surely Foundation have tested this? Along with resistance to custard pie and nerf gun assault?
.G6FIR
simpex
Sun Feb 08, 2015 10:50 am
The IR light emitted by a Remote Control for TV should also be tried to see if it has any effect on Raspberry Pi 2.
It should be also checked if the board is sensitive to Arc Welding.
Quite important, test Raspberry Pi in the street to see if it is sensitive to Xenon and other kinds of headlamps.
http://en.wikipedia.org/wiki/Headlamp#H ... ht_sources
gordon77
Sun Feb 08, 2015 10:55 am
simpex wrote:The IR light emitted by a Remote Control for TV should also be tried to see if it has any effect on Raspberry Pi 2.
A new feature - remote control reset built in ? ;)
Sun Feb 08, 2015 12:16 pm
Shining my TV remote directly at U16 had precisely zero effect. So that's a non-issue.
This is a doctor free zone.
jdb
Sun Feb 08, 2015 12:21 pm
Dupe, locking
Rockets are loud.
https://astro-pi.org
