Seiduna
Re: Power/Voltage Issues on B+
Sun Mar 01, 2015 8:12 pm
hey hey SteveDee, now we are talking!!!
All of you other guys, hang on a minute please:
How came these gpoi thingy did not came up earlier in this thread, or is it my bad english?
So, if I connect via gpio, than losses are less? Yes? No?
and I mean cut the cord, I get two wires, put one on ground and other on 5V? Yes? No?
Thank you
Gnu/Linux,
because I'd rather own a free OS
than steal one that's not worth paying for.
pluggy
Mon Mar 02, 2015 11:04 am
If you're sticking with a separate cable, look for ones that specify the gauge of cable, the better ones are 22swg or even better 20swg. A couple of yours do, but 28swg is very thin, 24 swg is better. And the shorter the better. The voltage and temperature ratings are largely immaterial.
This should work :
http://www.amazon.co.uk/PortaPow-Chargi ... B0088HTYUE
Good ones tend to be pricey, the official power supply is cheaper.
Connecting via GPIO is possible, but it bypasses the built in protection through the micro-USB socket.
I must not tread on too many sacred cows......
Rasperman
Mon Mar 02, 2015 11:43 am
Try a decent powered hub? :!:
SteveDee
Mon Mar 02, 2015 8:04 pm
Seiduna wrote:...and I mean cut the cord, I get two wires, put one on ground and other on 5V? ...
You are a dangerous guy Seiduna!
I did NOT suggest that you cut wires and hang your black-blob power supply on the GPIO. Why would you do that? What do you hope to achieve? It's a lose-lose strategy!
My suggestion is that you buy a cheap multimeter. You can then take voltage measurements while you swap black-blobs and cables, until you find a combination that gives a good 5V, and works. If none of them work, go out and buy the thickest USB cable you can find. If that still doesn't meet your power requirements, then buy a power supply like Nick's, which has been properly designed and built for the purpose.
Seiduna
Tue Mar 03, 2015 9:24 am
oi oi guys, hello,
well, I ordered original rPi power supply and it came in just now.
as I opened it it has the thinnest cable I've seen lately,
and I thought - this ain't gonna fly...
but... I connected and I am running scripts, and no rainbow!!!
oh, i spent too much money getting rPi right power,
and certainly too much of your time,
which I thank you and I do much appreciate.
Thank you all!
Gnu/Linux,
abishur
Tue Mar 03, 2015 3:29 pm
Seiduna wrote: oh, i spent too much money getting rPi right power,
I'm glad you got it all squared away. Poorly made chargers are definitely a big problem and I wish there was something we could do to more readily address it beyond warning people away from 99 cent adapters off eBay. (and sometimes even those 5 dollar chargers end up being counterfeit or cheap knock-offs that don't deliver what is advertised) :(
Dear forum: Play nice ;-)
pluggy
Tue Mar 03, 2015 10:51 pm
Seiduna wrote:oi oi guys, hello,
Thank you all!
The official power supply only has 2 conductors and no overall outer sheath, so a lot more of that thin cable is useful copper.
I get a solid 5V at the Pi when its feeding a USB powered hard drive with no hub.
