ssa9
Running an application
Fri Feb 06, 2015 5:27 am
I want to run an application using terminal to check if the JDK is properly working.I have downloaded JavaFx. What is the command to run an application. I also do not know which applications are installed on my pi. Could you please help with an example?
ghans
Re: Running an application
Fri Feb 06, 2015 6:25 am
java -v
javac -v
should at least tell you if the JRE/the JDK is in your $PATH.
ghans
EtonMess
Fri Feb 06, 2015 8:35 am
javaws -viewer
.G6FIR
