MircoSD Cards
Posted: Wed Feb 04, 2015 8:37 am
by nikrox
Hello everyone.
I was thinking of buying a Raspberry Pi 2 but i wanted to know if i could use my microsd card from my raspberry pi model b+.
Thanks in advance :D
Re: MircoSD Cards
Posted: Wed Feb 04, 2015 12:42 pm
by DirkS
Yes. And if you update / dist-upgrade it in your B+ first it should boot the Pi2B without problems.
Re: MircoSD Cards
Posted: Wed Feb 04, 2015 12:45 pm
by DougieLawson
Should just work. As long as you're right up to date with sudo apt-get update && sudo apt-get dist-upgrade
Re: MircoSD Cards
Posted: Wed Feb 04, 2015 3:00 pm
by marked
But you can't seem to go vice versa - new install of 2015-01-31 raspbian to a 16GB card, would fail booting at around cgroups when moved from an PI2 to an A+ (was configuring wifi) I don't think I changed either gpu memory split or overclock settings.
Any ideas?
Re: MircoSD Cards
Posted: Wed Feb 04, 2015 4:20 pm
by DirkS
marked wrote:But you can't seem to go vice versa - new install of 2015-01-31 raspbian to a 16GB card, would fail booting at around cgroups when moved from an PI2 to an A+ (was configuring wifi) I don't think I changed either gpu memory split or overclock settings.
Any ideas?
That should work too. What exactly do you call 'fail booting'?
Re: MircoSD Cards
Posted: Wed Feb 04, 2015 5:55 pm
by DougieLawson
The RPi2B uses /boot/kernel7.img and /lib/modules/3.18.5+-v7
The A+ uses /boot/kernel.img and /lib/modules/3.18.5+
Those are the only pieces that differ between the two.
My RPi2B booted from a card that I'd not used since April 2014 when I replaced those parts (using another RPiB). I'm 99.99% sure that would work if I shut it down and try it in my A+.
Re: MircoSD Cards
Posted: Fri Feb 06, 2015 5:43 am
by nikrox
Thanks everyone for their help.
:) :D :D :D :D
