Page 18 of 18
Re: The Raspberry Pi 2 Q&A thread
Posted: Tue Mar 03, 2015 11:52 am
by DougieLawson
pattagghiu wrote: can i assume now the "official" firmware (with dist-upgrade) is 3.18.8 or should i look elsewhere?
To get the leading edge 3.18.8 "firmware" and kernel you'll need to use rpi-update, the stock kernel with apt-get hasn't got past 3.18.7 yet.
Posted: Tue Mar 03, 2015 11:56 am
by Massi
Ok, so i'll stay there for now :)
Where can i see the stockversion? I need to upgrade wifi drivers before dist-upgrade :)
Posted: Thu Mar 05, 2015 2:24 pm
by Jo13310
Hello! I bought a RPi 2 with an adaptor 5V/2A. I'd like to buy a powered usb hub. The problem is backfeed from the USB port. I'm new in this and I really don't understand it all.
If someone could tell me which usb hub to buy and if backfeed wouldn't hurt my RPi that would be nice.
Thanks in advance
Posted: Thu Mar 05, 2015 6:36 pm
by W. H. Heydt
Jo13310 wrote:Hello! I bought a RPi 2 with an adaptor 5V/2A. I'd like to buy a powered usb hub. The problem is backfeed from the USB port. I'm new in this and I really don't understand it all.
Thanks in advance
This is the type of hub I use: http://www.mcmelectronics.com/product/83-12399
It doesn't backfeed.
Posted: Tue Mar 17, 2015 7:41 pm
by findx
jdb wrote:
findx wrote:
jdb wrote:The USB timer/counter was actually something that I requested - there's some Gert magic in there that means you can route the ARMCTRL FIQ to an arbitrary core and multiplex it with a very basic timer (19.2MHz/24-bit compare-counter) to get around some of the limitations in the OTG core.
Will specifics of the FIQ implementation be released? I currently use GPIO FIQ code on the Raspberry Pi 1 model B for somewhat fast data acquisition, and it'd be great to have some documentation on what needs to change to move it to the new multi-core architecture.
I believe the document detailing the ARM-local peripherals (i.e. implemented at the boundary of the Cortex-A7 block) is still confidential to licensees. I'll see if that's going to change anytime soon.
Just following up -- are there any updates?
Posted: Wed Jun 03, 2015 7:39 pm
by mob-i-l
How do you detect if the warranty bit is set on a Raspberry Pi 2 B? I found a test for Raspberry Pi 1 that I run on Raspberry Pi 2 and according to that the warranty bit is set on my computer, but I have only used microSD-cards with settings according to raspi-config.
cat /proc/cpuinfo
gives
Revision : a01041
Posted: Wed Jun 03, 2015 7:56 pm
by jdb
The A7 peripheral documents are up on our doc tree:
https://www.raspberrypi.org/documentati ... /README.md
mob-i-l wrote:How do you detect if the warranty bit is set on a Raspberry Pi 2 B? I found a test for Raspberry Pi 1 that I run on Raspberry Pi 2 and according to that the warranty bit is set on my computer, but I have only used microSD-cards with settings according to raspi-config.
cat /proc/cpuinfo
gives
Revision : a01041
viewtopic.php?p=687876#p687876
Bit 25 is the warranty bit. If the script is not updated for Pi2 then it'll mistake the revision scheme as the warranty bit.
Posted: Mon Jun 08, 2015 8:23 pm
by mob-i-l
davidcoton wrote:Possible solution: keep the overclock settings separate for Pi1 and Pi2, so that transferring to a different version will not activate the wrong set of settings :?
I also think this is a good idea because it would make it easier to move overclocked SD-cards between Pi1 and Pi2, and vice versa. AFAIK it works like this for the GPU-memory setting and different RAM.
Posted: Tue Jun 09, 2015 3:27 pm
by cedricj
Hi everybody,
I had a quick look in the forum but i didn't want to post in the "warranty" thread since I don't exactly talk about the same subject.
I had the luck to order a pi2 on its firsts days of availability on RS japanese website (I live in Japan) and it appeared that my pi crashed 2 weeks ago. I use it as a classic media center (openelec) through berryboot and sometimes Raspbian (still by berryboot) to make some tests.
The pi kept giving me a black screen and didn't boot so I first thought that it was caused by a card corruption (indeed it was) but after changing it yesterday I found that the boot stop at a point, doesn't go further and display a "kernel panic".
I didn't overclocked the pi, used a 5V2A power supply, unplugged and replugged the wire to restart the machine - well i usually do a "reboot" via ssh but I didn't have my phone near... -
So I wanted to have your opinion, do you think I can replace it under warranty? Since I didn't do anything abnormal with it (I used to do the same with my Pi 1 and never had any issues).
By advance thank you,
Cedric
Posted: Tue Jun 09, 2015 5:23 pm
by jamesh
Have you used a new SD card?
Posted: Wed Jun 10, 2015 1:11 am
by cedricj
jamesh wrote:Have you used a new SD card?
yes, I bought a new one because I wanted to extend the memory from the beginning. I tried to boot after copying the previous image or by setting up a new installation of berryboot but I got the same result.
Posted: Wed Jun 10, 2015 9:03 am
by jamesh
Can you try a raw installation of the latest Raspbian, rather than NOOBS or berryboot? That way we can be sure the software is the right version.
Posted: Wed Jun 10, 2015 2:45 pm
by cedricj
I tried to write the Raspbian wheezy 05-05 image by windows (I was a bit lazy and prefered the safest way) and the pi doesn't turn on when I plug the power supply :/
Posted: Wed Jun 10, 2015 3:06 pm
by jamesh
cedricj wrote:I tried to write the Raspbian wheezy 05-05 image by windows (I was a bit lazy and prefered the safest way) and the pi doesn't turn on when I plug the power supply :/
Did you use win32DiskImager - you need to use that with the raw ISO of Raspbian.
Posted: Wed Jun 10, 2015 3:08 pm
by fruitoftheloom
https://www.raspberrypi.org/documentati ... windows.md
Posted: Thu Jun 11, 2015 1:32 pm
by cedricj
yes I used win32DiskImager with an img file (from the zip file on the download section) and it didn't worked.
before that I tried to restore an image backup from weeks ago by the OSX terminal and got a partial boot (which stopped saying kernel panic)
Posted: Tue Jun 16, 2015 12:06 am
by cedricj
any similar feedback anyone? I think I can't solve it by a software fix so I'll ask the distributor for a product exchange :/
Posted: Wed Nov 11, 2015 12:16 pm
by ukusbobra
We need memory addresses of Secure Extensions(TrustZone) DRAM on Raspberry Pi 2. Base address and size. Maybe something like a memory map.
