Dhruvin Pipalia
Temperature Sensor DB18B20 Not Working
Wed Jan 28, 2015 2:40 pm
I have connected the pins of my sensor to the appropriate pins of raspberry pi and i write following two command
sudo mobprobe w1-gpio
sudo mobprobe w1-therm
after the i go to /sys/bus/w1/devices directory but it shows nothing..
what should i do?
i am using raspberry pi b+ model..
Re: Temperature Sensor DB18B20 Not Working
Wed Jan 28, 2015 7:14 pm
Dhruvin Pipalia wrote:sudo mobprobe w1-gpio
Is that a typo and you really used "modprobe"?
Check the modules have loaded with "lsmod | grep w1", like this
[email protected] ~ $ lsmod | grep w1
w1_therm                2866  0
w1_gpio                 2751  0
wire                   25349  2 w1_gpio,w1_therm
How have you wired the sensor?
It should be +v to 3.3V pin, gnd to 0v/GND pin, data to GPIO4 pin 7 and 4K7 resistor between data and +v.
Does the sensor get hot?
Which kernel version are you running? There were some changes between the 3.12.xx and the 3.18.xx kernels. Type "uname -r" to find out which one you are running.
pluggy
Thu Jan 29, 2015 2:11 pm
From experience , check and double check the wiring and orientation of the device.
RaTTuS
Thu Jan 29, 2015 2:21 pm
pluggy wrote:From experience , check and double check the wiring and orientation of the device.
and if it is HOT then you have wired it backwards
Covfefe
pluggy
Thu Jan 29, 2015 3:29 pm
I was going to say that but it slipped my mind. The device usually survives being wired backwards in my experience (I've done it a time or three.....)
Dhruvin Pipalia
Fri Jan 30, 2015 7:17 am
w1_therm                2866  0
w1_gpio                 2751  0
Typing mistake. i wrote "modprobe"
but hey i found the error since i updated my kernels i add these two links in the /boot/config.txt file
dtoverlay=w1-gpio,gpiopin=4
and now its showing
i read this solution is some post here but forgot the link so couldnt paste it here ..
but thanks for the reply.. :)
Dhruvin Pipalia
Fri Jan 30, 2015 7:18 am
I updated the kernel that was the probelm.
pluggy
Fri Jan 30, 2015 10:30 am
w1_therm                2866  0
w1_gpio                 2751  0
and now its showing
Rule number 1, never, ever, run rpi-update......
