expandables
Omxplayer waiting for dbus address to appear
Sun Jan 25, 2015 10:37 pm
Hi i updated my raspberry pi with
sudo rpi-update
.And now i am getting an error that says
I have a script in /etc/init.d that says
#! /bin/sh
### BEGIN INIT INFO
# Provides:          asplashscreen
# Required-Start:
# Required-Stop:
# Should-Start:
# Default-Start:     S
# Default-Stop:
# Short-Description: Show custom splashscreen
# Description:       Show custom splashscreen
### END INIT INFO
do_start () {
    omxplayer /home/pi/video.mov &
    exit 0
case "$1" in
  start|"")
    do_start
  restart|reload|force-reload)
    echo "Error: argument '$1' not supported" >&2
    exit 3
  stop)
    # No-op
  status)
    exit 0
    echo "Usage: asplashscreen [start|stop]" >&2
    exit 3
esac
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
expandables
Re: Omxplayer waiting for dbus address to appear
Mon Jan 26, 2015 12:21 am
Any Help?
ghans
Mon Jan 26, 2015 7:29 am
Can you try forcefully downgrading with an old
build form here :
http://omxplayer.sconde.net
sudo dpkg -i packagename.deb
to install.
ghans
expandables
Mon Jan 26, 2015 1:46 pm
Hi i tried that and thanks for the reply. I think the new firmware mess it up because it start saying
waiting for dbus address to appear when i recently did rpi-update
ghans
Tue Jan 27, 2015 7:56 am
Yes , try to downgrade your omxplayer forcefully with an
older version available through the link i posted.
ghans
gkreidl
Tue Jan 27, 2015 9:01 am
ghans wrote:Yes , try to downgrade your omxplayer forcefully with an
ghans
That must be a really old version, because dbus support was added about a year ago.
Minimal Kiosk Browser (kweb)
expandables
Tue Jan 27, 2015 3:09 pm
ghans
Hi same version from http://omxplayer.sconde.net/
Build date: 24/10/2014 00:55 UTC
Git version: 98982df
gkreidl
Tue Jan 27, 2015 3:16 pm
There's also a list of older versions.
expandables
Tue Jan 27, 2015 3:51 pm
gkreidl wrote:There's also a list of older versions.
Hi I tried many old builds omxplayer still says
If i move the script to rc.local or cron @reboot omxplayers plays the video at boot but if i run the script from /etc/init.d i get the message waiting for dbus address to appear.
It used to work fine before the recent rpi-update.
Douglas6
Tue Jan 27, 2015 4:53 pm
You might want to try changing the Required-Start: line in your init script to:
# Required-Start: dbus
expandables
Tue Jan 27, 2015 5:36 pm
Douglas6 wrote:You might want to try changing the Required-Start: line in your init script to:
Hi thanks for your reply but that still doesn't work :( :cry:
ghans
Tue Jan 27, 2015 6:10 pm
Run
sudo update-rc.d
to apply the change.
ghans
expandables
Tue Jan 27, 2015 6:35 pm
ghans wrote:Run
sudo update-rc.d
ghans
That does not work i get this
sudo update-rc.d
update-rc.d: using dependency based boot sequencing
update-rc.d: error: not enough arguments
usage: update-rc.d [-n] [-f] <basename> remove
       update-rc.d [-n] <basename> defaults [NN | SS KK]
       update-rc.d [-n] <basename> start|stop NN runlvl [runlvl] [...] .
       update-rc.d [-n] <basename> disable|enable [S|2|3|4|5]
                -n: not really
                -f: force
ghans
Tue Jan 27, 2015 7:06 pm
Try
sudo dpkg-reconfigure insserv sysv-rc
ghans
expandables
Tue Jan 27, 2015 7:13 pm
ghans wrote:Try
ghans
Thanks for the reply but that still doesn't work
Ian57
Thu Jan 29, 2015 1:15 pm
I had the same problem on raspicade... when updating today.
It comes from omxplayer. The asplashscreen script starts too early and some useful programs miss omxplayer.
The solution is to delay asplashscreen at boot :
desactivate asplashscreen
sudo insserv -r /etc/init.d/asplashscreen
copy it with a new name starting with a letter after A in the ABC ;-) (n is working for me but you can try previous letter after d, like f,
sudo cp /etc/init.d/asplashscreen /etc/init.d/nasplashscreen
we change in the nasplashscreen file the Provides variable
#!/bin/bash
### BEGIN INIT INFO
# Provides:          nasplashscreen
# Required-Start:
# Required-Stop:
activate the new script on startup
sudo insserv /etc/init.d/nasplashscreen
reboot it should work
The backward is that the video will appear later after powering up... because lots of things are loaded before the video ran by nasplashscreen
expandables
Thu Jan 29, 2015 3:04 pm
Hi thanks that works :D
Ian57
Thu Jan 29, 2015 3:08 pm
Of course that works I've done it :D
Douglas6
Thu Jan 29, 2015 3:24 pm
This implies the init system in Wheezy ignores the Required-Start prerequisites, and loads things in alphabetical order? That seems nuts to me.
expandables
Thu Jan 29, 2015 4:18 pm
Douglas6 wrote:This implies the init system in Wheezy ignores the Required-Start prerequisites, and loads things in alphabetical order? That seems nuts to me.
I guess they modified the new firmware. It sucks to wait 15+ seconds for video to load instead of 5.
xpeace
Sat Jan 31, 2015 9:58 pm
Same problem here, it does even crash the A+ I have here.
First thing is waiting for dbus address to appear, then the pi crashes on the line
... Checking if shift key is held down: Error opening dev/input/event.* no such file or directory ...
boom graphic gets crippled -> game over, seems a problem in the latest firmware release...
Jame_s
Wed Feb 04, 2015 4:51 pm
i have played a bit with this and it seems that if you put dbus as a requirement in the init info header it will fire the video as quickly as it can. you still have to give it a letter higher than d from what i can tell. i stuck with n.
#! /bin/sh
### BEGIN INIT INFO
# Provides: nsplashscreen
# Required-Stop:
# Should-Start:
# Default-Start: S
# Default-Stop:
### END INIT INFO
Jame_s
Wed Feb 04, 2015 6:42 pm
scratch that, after further investigation it doesnt seem to make a whole lot of difference.
the lowest letter i got to successfully run was j on my setup
expandables
Tue Feb 24, 2015 10:20 pm
I just got the raspberry pi 2 and doing this method my pi will not boot fully :cry: :shock:
rafaelmaeuer
Thu Mar 05, 2015 3:32 pm
I got it working with my Raspberry Pi 2!
I followed this Tutorial: https://www.youtube.com/watch?v=IX4f3BWOwAc
nasplashscreen:
#! /bin/sh
### BEGIN INIT INFO
# Required-Stop:
# Should-Start:
# Default-Start:      S
# Default-Stop:
### END INIT INFO
do_start () {
    omxplayer /home/pi/video.mp4 &
    exit 0
case "$1" in
  start|"")
    do_start
    exit 3
  stop)
    # No-op
  status)
    exit 0
    exit 3
esac
