tajiknomi
Running Tkinter on PI remotely
Sat Jan 17, 2015 11:34 am
I'm Connected to my PI on my Home Network.I'm using PUTTY to use the Interface of PI.
Whenever i try to Run a Gui program i-e tkinter, It doesn't Run Directly on PI, i had to copy "Xauthority" everytime i boot the PI using following Command in Shell.
"sudo cp ~pi/.Xauthority ~root/"
Then i'm able to run tkinter on PI, Its Irritating that i had to do this Everytime on Boot, Any Solution ?
ghans
Re: Running Tkinter on PI remotely
Sat Jan 17, 2015 1:00 pm
Does your program need root privileges (is invoked by sudo ?)
ghans
tajiknomi
Sat Jan 17, 2015 1:03 pm
Yes, Because i'm accessing the GPIO as well....
My program = https://dl.dropboxusercontent.com/u/16158781/all.py
ghans
Sat Jan 17, 2015 4:15 pm
Perhaps try using "gksudo" instead of "sudo" ?
ghans
tajiknomi
Sun Jan 18, 2015 2:13 pm
ghans wrote:Perhaps try using "gksudo" instead of "sudo" ?
ghans
That Worked like Charm,, thanks Bro :)
