I'm new to the PI, linux, etc, so please excuse what may be basic questions..
I used the command: sudo apt-get install qtcreator, on my raspberry pi, assuming it would install the latest version of QT Creator (which I believe is 5?)
Instead it installed a suite of QT4 apps.
Is there a way to install QT5 - which does NOT involve needing to download sources, then compiling those on the pi... Brief searches suggest this may be do-able, but we're hoping to avoid that..
Thanks in advance for any help,
Margarita
Re: QTCreator 5 for raspberry pi?
I have a package of Qt5.2 libraries that allow running of Qt apps in X Windows or directly to the frame buffer, no X in the way. Supports accelerated OpenGl graphics as well.
You can download the package from here http://the.linuxd.org/qt-5-2-for-raspberry-pi/ where there are also instructions for installation and use. Ignore the stuff about building it yourself.
I don't use QtCreator on the Pi. I do all development on a PC and then copy the sources over to the Pi and build them with a simple "qmake; make".
I'm sure this is mentioned here many times but there are "backports" packages of Qt5 you can install.
Edit the file: /etc/apt/sources.list and add:
Install the required key:
Then get Qt5 and esoteric requirements installed:
This will take some time, and install a plethora of packages.
I'm guessing a very recent version of QtCreator is also available as a package there.
deb http://twolife.be/raspbian/ wheezy main backports
deb-src http://twolife.be/raspbian/ wheezy main backports
$sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-key 2578B775
$ sudo apt-get update
$ sudo apt-get install qt5-default qt5-qmake libegl1-mesa libgles2-mesa
Thanks for your responses Heater.
But don't those final lines that you provide ($ sudo apt-get install qt5-default qt5-qmake libegl1-mesa libgles2-mesa) result in the building of source files from scratch?
What I've been asked to avoid, if possible, is actually building QT5 on the PI.
No they don't . They are just normal commands to install normal pre-built binary packages.
Your procedure is simple enough and apparently works. However, I have a problem with the last step. I have a Pi B+ with Rasbian OS installed. I have been a Linux User since before Fedora and didn't see any obvious problems while processing any of the previous commands you listed. The symptom is the message list below.
E: Unable to locate package qt5-default
E: Unable to locate package qt5-qmake
E: Unable to locate package libegl1-mesa
E: Unable to locate package libgles2-mesa
Would appreciate your help.
Sorry for sort of hijacking this a bit but I've been trying to get QT5 creator on a raspberry pi for about 2 weeks. All of the info I have found previously has been scattered, outdated, broken links, and or assumes you know linux. This is the closest I have found to something that you dont need to compile and it seems to work. Only extra thing I had to do was sudo leafpad /etc/apt/sources.list to be able to save changes to the sources list, otherwise I couldnt save changes there. I dont know if people are keeping quiet about how to do Qt on pi for a reason or if a lot is assumed.
I got through the instructions in this post but I dont see qt5 creator in any of the installed files. I couldnt find Qt5 creator on twolife's site either.
I had Qt4 creator from the short instructions margarita posted here but wiped it trying to get Qt5 stuff. I can get Qt4 creator again but learning Qt i'd rather start with 5. I know I'm missing something, i just dont know enough about this yet to know what it is. If anyone can point me to a semi-noobish way of getting Qt5 creator going on the pi or what i have to add to the sudo apt-get install qt5-____ I'd greatly appreciate it!
I am starting looking into compiling it on a linux box but i'd rather not reinvent the wheel if i can find one already.
I was hoping to get to doing live coding like this, https://www.youtube.com/watch?v=0j-Wakm5B84 to see my noob mistakes as i make them but I havent gotten close to that yet.
