Russed
UDEV rules
Sat Jan 10, 2015 2:12 pm
I am just starting work on a project and using python in an effort to learn it. The basic idea is on add a USB files get copied and on removal the pi reboots. I first wrote the udev rule for add.
/etc/udev/rules.d/999-usb.rules
KERNEL=="sd*1",ACTION=="add",RUN=="/home/pi/usb.sh"
the usb.sh
		#!/bin/bash
		cd /
		cd /home/pi/
		sudo python upload.py
		cd /
		exit
the python
		#!/usr/bin/python
		from os import walk
		import os
		os.system("sudo reboot")
and it worked, i place in a usb in and the sytem reboots ( this was so i colud make sure it worked) i added the part of the script to copy the contents
#!/usr/bin/python
from os import walk
import os
import shutil
src_files = os.listdir('/media/David/videos')
for file_name in src_files:
    full_file_name = os.path.join('/media/David/videos', file_name)
    if (os.path.isfile(full_file_name)):
        shutil.copy(full_file_name, '/home/pi/videos/')
print ("i'm done")
and tested it with "sh usb.sh" in a terminal window. worked perfectly however on plugging in the usb nothing. i have looked and i think udev runs as root so1 i'm not sure why its not working. i took the code back to one line and it works.
( the print was so i can see it a terminal window when it finishes this will be a message box with Tkinter)
PeterO
Re: UDEV rules
Sat Jan 10, 2015 2:17 pm
There is another approach, and that is to use pyudev to set up a listener for the events from udev.
I've done stuff with the "media change" events from cdrom drives to detect when disks are inserted and removed. I'm sure you can do the same with USB stick insertion and removal.
PeterO
hunternet93
Re: UDEV rules
Sun Jan 11, 2015 1:01 am
Try changing your udev rule to:
KERNEL=="sd*1",ACTION=="add",RUN=="sh /home/pi/usb.sh &> /tmp/script-log"
The "&>" symbol tells the shell to redirect the script's output and error messages to the file /tmp/script-log, once the script runs then any error messages should appear in that file, which you can read with your text editor of choice (i.e nano, vi, leafpad). If the file doesn't exist after plugging your USB drive then the script isn't running for some reason.
Russed
Re: UDEV rules
Sun Jan 11, 2015 10:14 am
Thanks hunternet93 and PeterO, i have tried adding the log and nothing was shown so it is not working. I have double checked today and the UDEV does run the shell script but stops when it gets to the python so i am now looking at pyudev, never heard of it so should be fun to learn. when i get it working i will post a reply.
topguy
Re: UDEV rules
Sun Jan 11, 2015 12:22 pm
Two things I would change in "usb.sh".
* Not use "sudo", you should be root anyway.
* Use full path to "python" binary. ( /usr/bin/python or something )
