farouk
GPIO Problem
Mon Dec 22, 2014 2:44 am
hi, I'm new in raspberry pi programming ,I try to test the code bellow but it cannot worked someone help me please :oops:
result
code
texy
Re: GPIO Problem
Mon Dec 22, 2014 7:35 am
I think it tells you what the problem is. What are you running it on - your PC?
(Hint : it would appear that you are NOT running the example code on a raspberry pi).
Texy
Re: GPIO Problem
Mon Dec 22, 2014 11:41 am
joan
Re: GPIO Problem
Mon Dec 22, 2014 12:00 pm
Assuming you are running on a Pi.
Perhaps you are running a custom kernel?
If so could you post the contents of /proc/cpuinfo?
joan
Re: GPIO Problem
Mon Dec 22, 2014 12:05 pm
If you want the Python to run on a PC but use the Pi's gpios (and the Pi is networked) you can use the pigpio Python module.
Re: GPIO Problem
Mon Dec 22, 2014 12:13 pm
It could be a RPi A+ or B+ with a version of RPi.GPIO that's too old to recognise the /proc/cpuinfo revision number.
farouk
Re: GPIO Problem
Mon Dec 22, 2014 6:12 pm
yes texty I running my raspberry pi B+ on my pc using ethernet câble "RG45"
DirkS
Re: GPIO Problem
Mon Dec 22, 2014 6:15 pm
farouk wrote:yes I running my raspberry pi B+ on my pc
How? Are you using an emulator?
joan
Re: GPIO Problem
Mon Dec 22, 2014 6:19 pm
If you have a Raspberry Pi on the same network as your PC you can use pigpio on your PC.
Alternatively you could use putty (or ssh on Linux) to log into your Pi from your PC and then use other Python modules actually on the Pi.
farouk
Re: GPIO Problem
Mon Dec 22, 2014 6:44 pm
yes I use a windows emulator for raspberry it's called "QEMU"
DirkS
Re: GPIO Problem
Mon Dec 22, 2014 6:58 pm
farouk wrote:yes I use a windows emulator for raspberry it's called "QEMU"
qemu is not the same as a RasPi.
You could try Dougie's suggestion: http://www.raspberrypi.org/forums/viewt ... 05#p658162
kusti8
Re: GPIO Problem
Mon Dec 22, 2014 11:27 pm
Why don't you connect your raspberry pi to your pc and then just ssh or vnc into it. If you don't have a pi, you can't use the gpios
