i am a newbie to raspberry pi & raspbian but i tried my best to install mjpg-streamer into
the raspberry pi B+ which i bought recently.
one weeks ago, i installed mjpg-streamer by using the method of many blog's in the web
but i don't know which procedure was done exactly
here and there ant pasted. consequently i failed to operate raspi cam through the method
i wanted at that time
the problem happened 3 days ago.
again i tried to perform mjpg-streamer view as per some blog's guidance and i took
the procedure in the v4l-utils as per attached no 1
as you see, i already installed the v4l-utils in the past time. so i started to follow the procedure
after v4l-utils installtion. when i finished the final procedure, suddenly it did work perfectly!
so i was very excited and i wanted to copy of procedure by using mouse like ms excel or word.
but it was my fault. by my mistake, i copied some content the bottome side of the screen,
as you see in the capture.
before i did $ sudo halt, the camera performed very well with low latency even there was attached
some mistyped command in the screen. but, after rebooting, it was not performed in order and
i was confused with the phenomenon.
so i removed the folder of v4l-utils and re-installed it.
but during the procedure of same command which i did last time, i experienced
many error different with the past time and i found some missing files in new v4l-utils
comparing with old one.
as you see in the attached capture no 1, there was a libtool and makefile.in and others in the v4l-utils.
but in the new v4l-utils, there was not the files and it made some problem to do the procedure accordingly.
if i follow the command ~$ git clone git://git.linuxtv.org/v4l-utils.git
or sudp apt-get install v4l-utils as per guidance, always i found there is some missing file in the folder.
pls refer attached capture of it.
so i tried to remember the bloger's address and the command i perfromed to install the old v4l-utils.
but i couldn't.
really i want to reinstall the v4l-utils like the same one at first time.
how can i find and install it?
really appreciate your advice heartily^^.
b.rgds
