akki5230
How to access the sd card folder from raspbian?
Thu Nov 20, 2014 3:04 pm
I want to access the files i've copied from windows pc to the sd card in which raspbian is installed. How to acces the files in raspberry pi in the raspbian OS?
alexeames
Re: How to access the sd card folder from raspbian?
Thu Nov 20, 2014 3:08 pm
they're probably in the directory (folder) caller /boot
So
cd /boot
ls -l
and you should see your files.
Alex Eames RasPi.TV, RasP.iO
akki5230
Fri Nov 21, 2014 8:33 am
This didn't list my files. By the way I figured it out: :)
I copied the files from a windows pc in the sd card , the card was RECOVERY partition which showed in windows. So the command wont show the recovery partion of sd card.
I mounted the recovery partition and got the files.. ;)
Loonhaunt
Tue Nov 25, 2014 2:40 am
I have an SD card that will no longer boot and would like to recover some files. Could you elaborate on how you mount the recovery partition to extract files?? Or recommend another thread?
Thanks,
Dave
Loonhaunt
Tue Nov 25, 2014 2:41 am
Thanks,
Dave
klricks
Tue Nov 25, 2014 4:02 am
Loonhaunt wrote:I have an SD card that will no longer boot and would like to recover some files. Could you elaborate on how you mount the recovery partition to extract files?? Or recommend another thread?
Thanks,
Dave
Several ways.....
- Find a Linux desktop with a cardreader.
- Obtain one of the many Linux Live boot CD and temporarily boot a Windows PC to Linux.
- Attach a USB card-reader to a working RPi and browse the SD card from there.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
