JonnyAlpha
Raspberry Pi Certified Educator
Recommended Displays
Mon Nov 03, 2014 1:40 pm
Hi;
Not sure exactly what small display I need or want but have been browsing EBay, there appear to be lots on offer.
Can anyone recommend small displays, or which ones to avoid, I am not sure what kind I really want or need yet so I am currently looking at both touch screen and standard displays small (3.5 and larger 7 inch ish)
There appear to be a lot more available on Ebay than when I first looked but I wanted some advice to avoid buying a duffer!!
A search for Raspberry Pi Displays brings up loads http://www.ebay.co.uk/sch/i.html?_from= ... y&_sacat=0
There are some real cheap ones (£15.99 2.8 Touch Screen) and some more expensive ones (49.99 7 Inch http://www.ebay.co.uk/itm/7-Screen-Boar ... 35dc4ceba9), if possible I'd also like some GPIO pins spare for other uses especially if use in a Robot but if used as a Multimedia Device it would not be so much of a problem I guess.
Possible future uses to give you some idea of what I am looking for would be:
1. Carputer / Car Multimedia Device.
2. Hand held retro game machine.
3. Display for AI Robot, to display a face (A bit like Holy from Red Dwarf) (Currently playing with Jasper Voice Recognition).
Raspberry Pi Certified Educator. Main Hardware - Raspberry Pi 1 model B revision 2, Raspberry Pi 2 model B, Pi Camera
JonnyAlpha
Re: Recommended Displays
Sat Nov 08, 2014 2:54 pm
Hi;
I thought I'd get a couple of responses to this, anyway, found a few more on Amazon, any thoughts:
The Tonec 3.5 Touch Screen:
http://www.amazon.co.uk/dp/B00LN9MYCO/r ... EZ9C&psc=1
And this 2.8 Touch Screen:
http://www.amazon.co.uk/dp/B00F1G7NNK/r ... RDQN3LD9HN
Sainsmart 7 Inch LCD Display - Reviews mention no instructions though?
http://www.amazon.co.uk/SainSmart-Displ ... i+displays
A Sainsmart 7 Inch Touch Screen - Mixed reviews on build quality and again instructions and power supply?
http://www.amazon.co.uk/SainSmart-Scree ... i+displays
And this Tontec 9 Inch LCD - No power cable though??
http://www.amazon.co.uk/Tontec%C2%AE-Ra ... i+displays
And an Adafruit 2.8 PiTFT
http://www.amazon.co.uk/Adafruit-Touchs ... i+displays
ReBoot
Mon Nov 10, 2014 2:20 pm
I recommend checking out Adafruit. This joint is run by electronic enthusiats and they offer great amount of ressources for all of their stuff.
BMS Doug
Tue Nov 11, 2014 9:00 am
JonnyAlpha wrote:Hi;
JonnyAlpha wrote:The Tonec 3.5 Touch Screen:
Mixed reviews on amazon, I have no personal experience. Supplied case is only suitable for A or B not A+ or B+.
JonnyAlpha wrote:And this 2.8 Touch Screen:
Very expensive for its size. I have no personal experience.
JonnyAlpha wrote:Sainsmart 7 Inch LCD Display - Reviews mention no instructions though?
Reviews of the board clarify the problems with assembly so you should be OK from there. No installation instructions required, plug the HDMI output of the Pi into the HDMI input of the controller board. No power cable supplied.
JonnyAlpha wrote:A Sainsmart 7 Inch Touch Screen - Mixed reviews on build quality and again instructions and power supply?
Assembly as above. Having to build the touchscreen drivers from the CD could be a hassle if you are unfamiliar with the process. No power cable supplied.
JonnyAlpha wrote:And this Tontec 9 Inch LCD - No power cable though??
No touchscreen, no mention of assembly instructions (but above review for sainsmart displays suggests that the Tontec displays do have instructions on their website). much like the sainsmart displays above except slightly larger. one reviewer mentions that the RPI text falls off the bottom of the screen, this might be fixable in HDMI settings.
JonnyAlpha wrote:And an Adafruit 2.8 PiTFT
I have one of these, the touch sensor has broken (broken connection from screen to board (within 2 days of purchase, or already broken when I got it, I'm not sure which)) and I find it too small for general use. I expect I'll find a project to use it on one day.
Doug.
tracerav
Sun Nov 16, 2014 9:15 pm
Ha, all!
All those displays are good, but are there any, which i can use with Display connector?
I do not want to use GPIO for LCD...
All modern LCDs have 4 lane LVDS interface and raspberry has 2 lanes...
Jessie
Mon Nov 17, 2014 2:48 am
tracerav wrote:Ha, all!
The raspberry pi has 0 LVDS lanes.
tracerav
Mon Nov 17, 2014 6:10 am
Jessie wrote:The raspberry pi has 0 LVDS lanes.
Jessie, thanks for your reply.
Maybe you can give me an advice, which LCD to use with this 30 pin display port? What for is this connector? All the solutions that i saw are using GPIO or HDMI connectors.
Mon Nov 17, 2014 6:52 am
The DSI connector is for the official Raspberry Pi Display, which is to be released "soon". Probably before the end of the year.
Apparently it is a non-trivial task to connect any other display as the interfaces are non-standard and the Pi will need firmware changes to support each individual display.
tracerav
Mon Nov 17, 2014 7:53 am
rpdom wrote:The DSI connector is for the official Raspberry Pi Display, which is to be released "soon". Probably before the end of the year.
Understood.
Thank you and good luck!
