CNC Mill Confusion - Stepper Motors
Posted: Mon Oct 27, 2014 11:31 pm
As a project this year I want to try and build a RPi desktop CNC mill. For the most part I will be machining wooden blocks however, in some cases for short periods of time I will need to machine metals such as mild steel (20mm max thickness) which do not require a high precision cut.
- What size motors are recommended for such tasks (ie Nema 17 75oz??).
- From what I have read up till now, the stepper motor driver plays a large role in power/torque output of the motor. I see lots of people using easydriver's which seem to be very cheap (around £0.99 on ebay) and some people using driver which cost as much a £20 each. What would you recommend for this application and is the difference really that big? I would also appreciate it if anyone has any recommendations or guidance on power supplies.
- Long lead times are not a problem (parts can be shipped from China), I found this website (http://www.omc-stepperonline.com/3-axis ... p-188.html) it seems to be FAR more cheaper than anywhere else I have seen however, seems too cheap. Firstly, are such parts from China really that cheap?! And is the quality decent? Secondly, would this kit not be ideal for the application?
If anyone has any recommended suppliers for any parts or have any experience with omc-stepperonline then please let me know (long lead times are not a problem).
As this is really my first "big" build I would appreciate it greatly if anyone has any guidance on this, even if it has nothing to do with the questions above please let me know.
