jojo_angelov
How does wpa_supplicant handle open networks with SSID ?
Wed Oct 22, 2014 5:04 pm
If I specify a network with an SSID and key_mgmt=NONE, and if I have several open networks, would the PI connect to the one that matches the SSID or just pick one that has no key? I am wanting the pi to only connect to MY open network and no other network.
mikerr
Re: How does wpa_supplicant handle open networks with SSID ?
Wed Oct 22, 2014 5:38 pm
It'll connect to the one that matches the SSID.
By default it will never connect to any unspecified SSID network, even open unsecured ones unless you add this:
network={
        key_mgmt=NONE
        priority=-999
The low priority just makes sure it connects to any of your known networks in preference
jojo_angelov
Wed Oct 22, 2014 6:19 pm
Thank you. That is all I wanted to know. Appreciate the help.
drew-kun
Tue Apr 10, 2018 7:08 pm
Do I understand it right, that for connecting to open unsecured network I may not specify the network SSID and just have the following code:
network={
        key_mgmt=NONE
        priority=-999
Because from what I have read in wpa_supplicant.conf man pages, the `ssid=` statement is required
