raspbian to replace openelec
Posted: Wed Oct 08, 2014 11:52 pm
by deonwessels
I am still a total noob with raspberry pi's. I want to replace openelec with raspian - I have downloaded noobs and saved onto the sd card. The Pi does not connect to the screen when I power up with the sd card in place..Any suggestions would be appreciated, thank you.
Re: raspbian to replace openelec
Posted: Thu Oct 09, 2014 4:15 am
by elatllat
what are your lights doing?
http://elinux.org/R-Pi_Troubleshooting
If you just want raspbian there is no need for noobs
how did you put the img on the card?
Posted: Thu Oct 09, 2014 4:52 am
by deonwessels
I initially installed openelec, which worked ok. I then copied and pasted raspian onto the sd card.( used the noobs download for that.) any suggestion where I should get Raspian from?
The red and green lights turn on but my display doesn't.
Many thanks.
Posted: Thu Oct 09, 2014 5:31 am
by fruitoftheloom
deonwessels wrote:I initially installed openelec, which worked ok. I then copied and pasted raspian onto the sd card.( used the noobs download for that.) any suggestion where I should get Raspian from?
Many thanks.
Read the sticky:
http://www.raspberrypi.org/forums/viewt ... 28&t=58151
Though it is likely you have not created the SD Card correctly:
http://www.raspberrypi.org/help/noobs-setup
Posted: Thu Oct 09, 2014 7:41 am
by deonwessels
Thanks very much for the suggestions - I tried reformatting the the sd card with FULL OVERWRITE and it is all systems go .
