Re: CEC
http://www.raspberrypi.org/forums/viewt ... 29&t=53481vibez wrote:Does anyone know the cec command to tell all connected devices that the rpi is shutdown / standby?
Re: CEC
http://www.raspberrypi.org/forums/searc ... ywords=cecvibez wrote:Thanks but it's not listed there
- DougieLawson
- Contact: Website Twitter
Re: CEC
Once the RPi is halted how will it send any CEC command? Or are you looking for something that runs as part of boot/shutdown before the RPi reaches its halted state.vibez wrote:Does anyone know the cec command to tell all connected devices that the rpi is shutdown / standby?
http://www.cec-o-matic.com/ says to send a 0x36 message to set everyone to standby. Or do you mean an "inactive source" 0x9D message?
Re: CEC
It doesn't need to halt, it just needs to either send an inactive command or change the active source to another device.
This is my current bus information
this is what happens when I try to set the rpi as the active source
Then if I scan the bus again, I see that nothing actually got set as the active source
CEC bus information
device #0: TV
address: 0.0.0.0
active source: no
vendor: Panasonic
osd string: TV
CEC version: 1.3a
power status: on
language: eng
device #4: Playback 1
address: 1.1.0.0
active source: no
vendor: Panasonic
osd string: CECTester
CEC version: 1.4
power status: on
language: eng
device #5: Audio
address: 1.0.0.0
active source: no
vendor: Unknown
osd string: HDCVT Main
CEC version: 1.4
power status: on
language: ???
pi@raspbmc:~$ echo "as" | cec-client -s
opening a connection to the CEC adapter...
DEBUG: [ 83] unregistering all CEC clients
DEBUG: [ 84] Broadcast (F): osd name set to 'Broadcast'
DEBUG: [ 85] InitHostCEC - vchiq_initialise succeeded
DEBUG: [ 85] InitHostCEC - vchi_initialise succeeded
DEBUG: [ 86] InitHostCEC - vchi_connect succeeded
DEBUG: [ 87] logical address changed to Broadcast (f)
DEBUG: [ 88] RegisterLogicalAddress - registering address e
DEBUG: [ 269] logical address changed to Playback 1 (4)
DEBUG: [ 270] logical address changed to Free use (e)
DEBUG: [ 270] Open - vc_cec initialised
NOTICE: [ 270] connection opened
DEBUG: [ 271] processor thread started
DEBUG: [ 271] << Broadcast (F) -> TV (0): POLL
DEBUG: [ 272] initiator 'Broadcast' is not supported by the CEC adapter. using 'Free use' instead
TRAFFIC: [ 273] << e0
DEBUG: [ 304] >> POLL sent
DEBUG: [ 304] TV (0): device status changed into 'present'
DEBUG: [ 304] << requesting vendor ID of 'TV' (0)
TRAFFIC: [ 304] << e0:8c
TRAFFIC: [ 516] >> 0f:87:00:80:45
DEBUG: [ 517] >> TV (0) -> Broadcast (F): device vendor id (87)
DEBUG: [ 517] TV (0): vendor = Panasonic (008045)
DEBUG: [ 518] expected response received (87: device vendor id)
DEBUG: [ 518] replacing the command handler for device 'TV' (0)
NOTICE: [ 519] registering new CEC client - v2.0.5
DEBUG: [ 519] detecting logical address for type 'playback device'
DEBUG: [ 519] trying logical address 'Playback 1'
DEBUG: [ 520] << Playback 1 (4) -> Playback 1 (4): POLL
TRAFFIC: [ 520] << 44
DEBUG: [ 521] UnregisterLogicalAddress - releasing previous logical address
DEBUG: [ 525] logical address changed to Broadcast (f)
DEBUG: [ 526] RegisterLogicalAddress - registering address 4
DEBUG: [ 797] logical address changed to Free use (e)
DEBUG: [ 797] logical address changed to Playback 1 (4)
TRAFFIC: [ 797] << 44
DEBUG: [ 797] >> POLL not sent
DEBUG: [ 798] using logical address 'Playback 1'
DEBUG: [ 798] Playback 1 (4): device status changed into 'handled by libCEC'
DEBUG: [ 798] Playback 1 (4): power status changed from 'unknown' to 'on'
DEBUG: [ 798] Playback 1 (4): vendor = Pulse Eight (001582)
DEBUG: [ 798] Playback 1 (4): CEC version 1.4
DEBUG: [ 798] AllocateLogicalAddresses - device '0', type 'playback device', LA '4'
DEBUG: [ 798] Playback 1 (4): osd name set to 'CECTester'
DEBUG: [ 798] Playback 1 (4): menu language set to 'eng'
DEBUG: [ 800] GetPhysicalAddress - physical address = 1100
DEBUG: [ 800] AutodetectPhysicalAddress - autodetected physical address '1100'
DEBUG: [ 800] Playback 1 (4): physical address changed from ffff to 1100
DEBUG: [ 801] << Playback 1 (4) -> broadcast (F): physical adddress 1100
TRAFFIC: [ 801] << 4f:84:11:00:04
NOTICE: [ 953] CEC client registered: libCEC version = 2.1.4, client version = 2.0.5, firmware version = 1, logical address(es) = Playback 1 (4) , physical address: 1.1.0.0, host: arm-bcm2708hardfp-linux-gnueabi, features: 'P8 USB' 'P8 USB detect' 'RPi', git revision: 81e3821, compiled on: Mon Dec 23 06:06:42 UTC 2013 by root@ on Linux 3.2.0-35-generic (x86_64)
DEBUG: [ 953] Playback 1 (4): vendor = Panasonic (008045)
DEBUG: [ 953] replacing the command handler for device 'Playback 1' (4)
DEBUG: [ 953] << Playback 1 (4) -> TV (0): OSD name 'CECTester'
TRAFFIC: [ 953] << 40:47:43:45:43:54:65:73:74:65:72
DEBUG: [ 1254] << requesting power status of 'TV' (0)
TRAFFIC: [ 1254] << 40:8f
TRAFFIC: [ 1435] >> 04:00:47:00
DEBUG: [ 1435] >> TV (0) -> Playback 1 (4): feature abort ( 0)
DEBUG: [ 1435] marking opcode 'set osd name' as unsupported feature for device 'TV'
TRAFFIC: [ 1512] >> 04:90:00
DEBUG: [ 1513] >> TV (0) -> Playback 1 (4): report power status (90)
DEBUG: [ 1513] TV (0): power status changed from 'unknown' to 'on'
DEBUG: [ 1513] expected response received (90: report power status)
DEBUG: [ 1514] making Playback 1 (4) the active source
NOTICE: [ 1514] >> source activated: Playback 1 (4)
DEBUG: [ 1514] sending active source message for 'Playback 1'
TRAFFIC: [ 1515] << 40:89:10:02:ff:ff:00:05:05:45:55:5c:58:32
NOTICE: [ 1875] << powering on 'TV' (0)
TRAFFIC: [ 1876] << 40:04
NOTICE: [ 1966] << Playback 1 (4) -> broadcast (F): active source (1100)
TRAFFIC: [ 1967] << 4f:82:11:00
TRAFFIC: [ 2207] >> 04:00:89:03
DEBUG: [ 2208] >> TV (0) -> Playback 1 (4): feature abort ( 0)
DEBUG: [ 2209] << Playback 1 (4) -> TV (0): menu state 'activated'
TRAFFIC: [ 2209] << 40:8e:00
TRAFFIC: [ 2359] >> 04:8c
DEBUG: [ 2360] >> TV (0) -> Playback 1 (4): give device vendor id (8C)
DEBUG: [ 2360] << Playback 1 (4) -> TV (0): vendor id Panasonic (8045)
TRAFFIC: [ 2360] << 4f:87:00:80:45
DEBUG: [ 2361] unregistering all CEC clients
NOTICE: [ 2362] unregistering client: libCEC version = 2.1.4, client version = 2.0.5, firmware version = 1, logical address(es) = Playback 1 (4) , physical address: 1.1.0.0, host: arm-bcm2708hardfp-linux-gnueabi, features: 'P8 USB' 'P8 USB detect' 'RPi', git revision: 81e3821, compiled on: Mon Dec 23 06:06:42 UTC 2013 by root@ on Linux 3.2.0-35-generic (x86_64)
DEBUG: [ 2511] Playback 1 (4): power status changed from 'on' to 'unknown'
DEBUG: [ 2511] Playback 1 (4): vendor = Unknown (000000)
DEBUG: [ 2511] Playback 1 (4): CEC version unknown
DEBUG: [ 2511] Playback 1 (4): osd name set to 'Playback 1'
DEBUG: [ 2511] marking Playback 1 (4) as inactive source
DEBUG: [ 2512] Playback 1 (4): device status changed into 'unknown'
DEBUG: [ 2512] unregistering all CEC clients
WARNING: [ 2781] unhandled response received: opcode=87 initiator=4 destination=f response=0
TRAFFIC: [ 2781] >> 04:89:10:01:03
DEBUG: [ 2781] >> TV (0) -> Playback 1 (4): vendor command (89)
WARNING: [ 3143] unhandled response received: opcode=89 initiator=4 destination=0 response=0
DEBUG: [ 3280] UnregisterLogicalAddress - releasing previous logical address
DEBUG: [ 3281] logical address changed to Broadcast (f)
pi@raspbmc:~$ echo scan | cec-client -s -d 1
requesting CEC bus information ...
CEC bus information
device #0: TV
address: 0.0.0.0
active source: no
vendor: Panasonic
osd string: TV
CEC version: 1.3a
power status: on
language: eng
address: 1.1.0.0
active source: no
vendor: Panasonic
CEC version: 1.4
power status: on
language: eng
device #5: Audio
address: 1.0.0.0
active source: no
vendor: Unknown
CEC version: 1.4
power status: on
language: ???
