#!/usr/bin/python
from __future__ import absolute_import, division, print_function, unicode_literals
''' Simplified slideshow system using ImageSprite and without threading for background
loading of images (so may show delay for v large images).
Also has a minimal use of PointText and TextBlock system with reduced codepoints
and reduced grid_size to give better resolution for large characters.
Also shows a simple use of MQTT to control the slideshow parameters remotely
see http://pi3d.github.io/html/FAQ.html and https://www.thedigitalpictureframe.com/control-your-digital-picture-frame-with-home-assistents-wifi-presence-detection-and-mqtt/
and https://www.cloudmqtt.com/plans.html
USING exif info to rotate images
ESC to quit, 's' to reverse, any other key to move on one.
import os
import time
import random
import demo
import pi3d
from PIL import Image, ExifTags # these are needed for getting exif data from images
# these variables are constants
#PIC_DIR = '/home/pi/pi3d_demos/textures' #'textures'
PIC_DIR = '/home/patrick/python/pi3d_demos/textures/temp' #'textures'
FPS = 20
FIT = True
EDGE_ALPHA = 0.0 # see background colour at edge. 1.0 would show reflection of image
BACKGROUND = (0.2, 0.2, 0.2, 1.0)
RESHUFFLE_NUM = 5 # times through before reshuffling
FONT_FILE = '/home/patrick/python/pi3d_demos/fonts/NotoSans-Regular.ttf'
CODEPOINTS = '1234567890ABCDEFGHIJKLMNOPQRSTUVWXYZ., _-/' # limit to 49 ie 7x7 grid_size
USE_MQTT = True
# these variables can be altered using mqtt messaging
time_delay = 10.0 # between slides
fade_time = 3.0
shuffle = True # shuffle on reloading
date_from = None
date_to = None
quit = False
paused = False # NB must be set to True after the first iteration of the show!
delta_alpha = 1.0 / (FPS * fade_time) # delta alpha
# some functions to tidy subsequent code
def tex_load(fname, orientation):
try:
im = Image.open(fname)
if orientation > 4: # this is a rotated image)
im = im.transpose(Image.ROTATE_270)
if orientation in [2, 4, 5, 8]:
im = im.transpose(Image.FLIP_LEFT_RIGHT)
if orientation in [4, 8]:
im = im.transpose(Image.FLIP_TOP_BOTTOM)
tex = pi3d.Texture(im, blend=True, m_repeat=True)
except Exception as e:
print('''Couldn't load file {}
(probably related to Apple and or Adobe making assumptions about hardware!!): {}'''.format(fname, e))
tex = None
return tex
def tidy_name(path_name):
name = os.path.basename(path_name).upper()
name = ''.join([c for c in name if c in CODEPOINTS])
return name
def get_files(dt_from=None, dt_to=None):
# dt_from and dt_to are either None or tuples (2016,12,25)
if dt_from is not None:
dt_from = time.mktime(dt_from + (0, 0, 0, 0, 0, 0))
if dt_to is not None:
dt_to = time.mktime(dt_to + (0, 0, 0, 0, 0, 0))
global shuffle, PIC_DIR, EXIF_DATID
file_list = []
extensions = ['.png','.jpg','.jpeg'] # can add to these
for root, _dirnames, filenames in os.walk(PIC_DIR):
for filename in filenames:
ext = os.path.splitext(filename)[1].lower()
if ext in extensions and not '.AppleDouble' in root and not filename.startswith('.'):
file_path_name = os.path.join(root, filename)
include_flag = True
orientation = 1 # this is default - unrotated
if EXIF_DATID is not None and EXIF_ORIENTATION is not None:
try:
im = Image.open(file_path_name) # lazy operation so shouldn't load (better test though)
#print(filename, end="")
exif_data = im._getexif()
print('orientation is {}'.format(exif_data[EXIF_ORIENTATION]))
dt = time.mktime(
time.strptime(exif_data[EXIF_DATID], '%Y:%m:%d %H:%M:%S'))
orientation = int(exif_data[EXIF_ORIENTATION])
except Exception as e: # NB should really check error here but it's almost certainly due to lack of exif data
print(e)
dt = os.path.getmtime(file_path_name) # so use file last modified date
if (dt_from is not None and dt < dt_from) or (dt_to is not None and dt > dt_to):
include_flag = False
if include_flag:
file_list.append((file_path_name, orientation)) # iFiles now list of tuples (file_name, orientation)
if shuffle:
random.shuffle(file_list) # randomize pictures
else:
file_list.sort() # if not suffled; sort by name
return file_list, len(file_list) # tuple of file list, number of pictures
EXIF_DATID = None # this needs to be set before get_files() above can extract exif date info
EXIF_ORIENTATION = None
for k in ExifTags.TAGS:
if ExifTags.TAGS[k] == 'DateTimeOriginal':
EXIF_DATID = k
if ExifTags.TAGS[k] == 'Orientation':
EXIF_ORIENTATION = k
# MQTT functionality - see https://www.thedigitalpictureframe.com/
if USE_MQTT:
try:
import paho.mqtt.client as mqtt
def on_connect(client, userdata, flags, rc):
print("Connected to MQTT broker")
def on_message(client, userdata, message):
# TODO not ideal to have global but probably only reasonable way to do it
global next_pic_num, iFiles, nFi, date_from, date_to, time_delay
global delta_alpha, fade_time, shuffle, quit, paused, nexttm
msg = message.payload.decode("utf-8")
reselect = False
if message.topic == "frame/date_from": # NB entered as mqtt string "2016:12:25"
df = msg.split(":")
date_from = tuple(int(i) for i in df)
reselect = True
elif message.topic == "frame/date_to":
df = msg.split(":")
date_to = tuple(int(i) for i in df)
reselect = True
elif message.topic == "frame/time_delay":
time_delay = float(msg)
elif message.topic == "frame/fade_time":
fade_time = float(msg)
elif message.topic == "frame/shuffle":
shuffle = True if msg == "True" else False
reselect = True
elif message.topic == "frame/quit":
quit = True
elif message.topic == "frame/paused":
paused = not paused # toggle from previous value
elif message.topic == "frame/back":
next_pic_num -= 2
if next_pic_num < -1:
next_pic_num = -1
nexttm = time.time() - 1.0
if reselect:
iFiles, nFi = get_files(date_from, date_to)
next_pic_num = 0
# set up MQTT listening
client = mqtt.Client()
client.username_pw_set("orhellow", "z6kfIctiONxP") # replace with your own id
client.connect("postman.cloudmqtt.com", 16845, 60) # replace with your own server
client.loop_start()
client.subscribe("frame/date_from", qos=0)
client.subscribe("frame/date_to", qos=0)
client.subscribe("frame/time_delay", qos=0)
client.subscribe("frame/fade_time", qos=0)
client.subscribe("frame/shuffle", qos=0)
client.subscribe("frame/quit", qos=0)
client.subscribe("frame/paused", qos=0)
client.subscribe("frame/back", qos=0)
client.on_connect = on_connect
client.on_message = on_message
print("MQTT not set up because of: {}".format(e))
DISPLAY = pi3d.Display.create(x=20,y=20,frames_per_second=FPS, background=BACKGROUND)
CAMERA = pi3d.Camera(is_3d=False)
shader = pi3d.Shader("/home/patrick/python/pi3d_demos/shaders/blend_new")
slide = pi3d.Sprite(camera=CAMERA, w=DISPLAY.width, h=DISPLAY.height, z=5.0)
slide.set_shader(shader)
slide.unif[47] = EDGE_ALPHA
kbd = pi3d.Keyboard()
# images in iFiles list
nexttm = 0.0
next_pic_num = 0
sfg = None # slide for background
sbg = None # slide for foreground
if nFi == 0:
print('No files selected!')
exit()
# PointText and TextBlock
font = pi3d.Font(FONT_FILE, codepoints=CODEPOINTS, grid_size=7, shadow_radius=4.0,
shadow=(0,0,0,128))
text = pi3d.PointText(font, CAMERA, max_chars=200, point_size=50)
textblock = pi3d.TextBlock(x=-DISPLAY.width * 0.5 + 50, y=-DISPLAY.height * 0.4,
z=0.1, rot=0.0, char_count=199,
text_format="{}".format(tidy_name(iFiles[next_pic_num][0])), size=0.99,
spacing="F", space=0.02, colour=(1.0, 1.0, 1.0, 1.0))
text.add_text_block(textblock)
num_run_through = 0
while DISPLAY.loop_running():
tm = time.time()
if nFi > 0:
if tm > nexttm and not paused: # this must run first iteration of loop
nexttm = tm + time_delay
a = 0.0 # alpha - proportion front image to back
sbg = sfg
sfg = None
while sfg is None: # keep going through until a usable picture is found TODO break out how?
pic_num = next_pic_num
sfg = tex_load(*iFiles[pic_num]) # '*' here splits tuple into two values
next_pic_num += 1
if next_pic_num >= nFi:
num_run_through += 1
if shuffle and num_run_through >= RESHUFFLE_NUM:
num_run_through = 0
random.shuffle(iFiles)
next_pic_num = 0
if sbg is None: # first time through
sbg = sfg
slide.set_textures([sfg, sbg])
slide.unif[45:47] = slide.unif[42:44] # transfer front width and height factors to back
slide.unif[51:53] = slide.unif[48:50] # transfer front width and height offsets
wh_rat = (DISPLAY.width * sfg.iy) / (DISPLAY.height * sfg.ix)
if (wh_rat > 1.0 and FIT) or (wh_rat <= 1.0 and not FIT):
sz1, sz2, os1, os2 = 42, 43, 48, 49
else:
sz1, sz2, os1, os2 = 43, 42, 49, 48
wh_rat = 1.0 / wh_rat
slide.unif[sz1] = wh_rat
slide.unif[sz2] = 1.0
slide.unif[os1] = (wh_rat - 1.0) * 0.5
slide.unif[os2] = 0.0
# set the file name as the description
textblock.set_text(text_format="{}".format(tidy_name(iFiles[pic_num][0])))
text.regen()
if a < 1.0:
a += delta_alpha
slide.unif[44] = a
# this sets alpha for the TextBlock from 0 to 1 then back to 0
textblock.colouring.set_colour(alpha=(1.0 - abs(1.0 - 2.0 * a)))
text.regen()
slide.draw()
else:
textblock.set_text("NO IMAGES SELECTED")
textblock.colouring.set_colour(alpha=1.0)
text.regen()
text.draw()
k = kbd.read()
if k != -1:
if k==27 or quit: #ESC
break
if k==ord(' '):
paused = not paused
if k==ord('s'): # go back a picture
next_pic_num -= 2
next_pic_num = -1
try:
client.loop_stop()
print("this was going to fail if previous try failed!")
kbd.close()
DISPLAY.destroy()
diff PictureFrame.py PictureFrame_rotate.py
10a11,12
50c52
< def tex_load(fname):
52c54,61
< tex = pi3d.Texture(fname, blend=True, m_repeat=True)
79c88,89
< if EXIF_DATID is not None and (dt_from is not None or dt_to is not None):
82a93,94
84c96,97
< time.strptime(im._getexif()[EXIF_DATID], '%Y:%m:%d %H:%M:%S'))
91c104
< file_list.append(file_path_name)
98a112
102c116,118
< break
193c209
< text_format="{}".format(tidy_name(iFiles[next_pic_num])), size=0.99,
208c224
< sfg = tex_load(iFiles[pic_num])
232c248
< textblock.set_text(text_format="{}".format(tidy_name(iFiles[pic_num])))
Paddy
