Unable to disable splash screen
Posted: Fri Sep 12, 2014 12:26 pm
by Raspburrito
Hi fellow Raspberrians,
I've been having some bad time trying to disable the splash screen on boot (actually, the 4 colour enlarged pixels).
I follow the instructions that are everywhere, changing the /boot/config.txt file as root, adding disable_splash=1, and nothing happens at all, it keeps showing up the pixels on boot.
I'm using Raspbian installed via the latest version of NOOBS, and for the record I still get other options to work by editing the file, like the screen rotation for example.
Am I doing something wrong? Or can the splash not be disabled any longer?
I used to love the way I could change (not too easy not too hard) features like this one, but It is kind of sad how I got stucked with it.
Thanks in advance for any help,
Re: Unable to disable splash screen
Posted: Fri Sep 12, 2014 1:07 pm
by RaTTuS
have you edited the config.txt file in the correct location - if you are using noobs then it is the one in the recovery partition IIRC
Posted: Fri Sep 12, 2014 4:05 pm
by AndrewS
RaTTuS is right - there's a few very early-stage parameters in config.txt that are read by bootcode.bin, and the rest (the majority) that are read by start.elf. On NOOBS bootcode.bin is loaded (at power-on) from /dev/mmcblk0p1, and start.elf is loaded from the boot partition of your OS (typically /dev/mmcblk0p5).
So to control early-stage things like the splash-screen you need to edit the config.txt that is read by bootcode.bin, i.e. add a config.txt to /dev/mmcblk0p1 (the RECOVERY partition).
Alternatively, you could use autoboot.txt with NOOBS which also bypasses the coloured splash screen https://github.com/raspberrypi/noobs#ho ... -partition
Posted: Fri Sep 12, 2014 4:23 pm
by PiGraham
Raspburrito wrote:Hi fellow Raspberrians,
Do you mean the 'rainbow screen'?
I'm not sure if you can disable that with text file settings in /boot.
I don't think it displays on a Buildroot boot. I think it's produced by the GPU before it runs any Arm code.
Posted: Fri Sep 12, 2014 6:28 pm
by Raspburrito
AndrewS wrote:RaTTuS is right - there's a few very early-stage parameters in config.txt that are read by bootcode.bin, and the rest (the majority) that are read by start.elf. On NOOBS bootcode.bin is loaded (at power-on) from /dev/mmcblk0p1, and start.elf is loaded from the boot partition of your OS (typically /dev/mmcblk0p5).
Well no luck, I should have said I'm a total noob.
The only config.txt file I have access to is inside the /boot/. I found the /dev/mmcblk0p1 and it is a 'block device' I cannot seem to edit, at least not with my current knowledge, so I have no clue how to "add a config.txt to /dev/mmcblk0p1 (the RECOVERY partition)"...
I sadly had to work around the issue: installed Raspbian without NOOBS, now it works like a charm, simply add disable_splash=1 on /boot/config.txt, and done, the rainbow screen is gone (or black).
Thanks everyone,
Posted: Thu Jul 21, 2016 2:28 pm
by cresfang
If you wanna copy config.txt to NOOBS recovery partition, do this in terminal:
cd /boot
sudo mkdir /media/recovery
sudo mount /dev/mmcblk0p1 /media/recovery/
sudo cp config.txt /media/recovery/
sudo reboot
VOILA! The splash is disabled this way.
The NOOBS's wiki using autoboot.txt didn't work for me.
