Electrical specifications BCM2835
Posted: Thu Sep 11, 2014 6:47 pm
Where can I find the electrical charactristics of the BCM ports? I've found, only barely mentioned, something about the Vil and Voh and nothing more, or maybe on the current. Otherwise some of my projects can not ad affordable as I want to design them. I just stepped in a problem of minumum voltage of a digital value today, solved just with some luck. I discovered that the Vil is around 0.8V, but for sure I can't keep discovering things in such a way.
Is that possible that the electrical considerations are not publicly available? If not, can anyone provide some link? I'm just referring to capacitances, open drain capability, currents, voltages, absolute values and the usual stuff related to that.
Thanks!!
Thanks!!
