Dual OS's on Same SD Card
Posted: Tue Sep 09, 2014 9:42 pm
by Des804
I really hope it is alright to post this question here. I was given my very first Raspberry as a Birthday gift recently and was wondering if it possible to have a dual OSes on the same SD card. I only ask because I have Raspian on 1 SD card and I recently found another 16g SD card for the price of an 8g so I had to pick it up because I had wanted to try doing openelec to try and do a media player of sorts and was wondering if it would be possible for there to be 2 OSs on the same card in case I see another OS I want to play with.
Re: Dual OS's on Same SD Card
Posted: Tue Sep 09, 2014 9:45 pm
by mahjongg
Yes, if you use NOOBS as the installer, you can select multiple OS for installation, and NOOBS will start with a bootmenu.
alternatively you can manually install multiple OS, and use an utility called berryboot for the boot menu.
Posted: Tue Sep 09, 2014 9:52 pm
by Des804
Ok I don't know if Noobs has Openelec as an option but I will definitely Look into that berryboot. May I ask if anyone has any suggestions of other OS that are good to try out ( I don't know what I want to do with this Raspi so I can't tell you where Im headed with it). I do know I am going to try and control my light switch using a Relay board at some point in time.
Posted: Tue Sep 09, 2014 11:41 pm
by mahjongg
most people will use Raspbian, as its simply the default linux OS for the PI, but really any OS can be used to do this, having a good GPIO library helps though (and raspbian has it), but have a look at RiscOS too.
Posted: Wed Sep 10, 2014 6:03 pm
by Des804
I've got a question the XMBC that people are refering to is RaspMBC the same as in will it use the remote app that you can put on your phone (For when I do connect to Wifi on my raspberry) along with playing movies straight from USB ?. I was pondering doing Openelec and Raspmbc.
Posted: Wed Sep 10, 2014 7:30 pm
by kusti8
Des804 wrote:I've got a question the XMBC that people are refering to is RaspMBC the same as in will it use the remote app that you can put on your phone (For when I do connect to Wifi on my raspberry) along with playing movies straight from USB ?. I was pondering doing Openelec and Raspmbc.
I use openelec. Raspbmc was based on raspbian and is a tiny bit slower than openelec, which was built from scratch.
Posted: Thu Sep 11, 2014 2:30 am
by Des804
I only ask about the XMBC because I like the ability to control it using my Wifi Smartphone with an app. Can you do the same in Openelec ? This is also why I am wanting to put both onto the 16g Sd Card
Posted: Thu Sep 11, 2014 11:30 am
by kusti8
Des804 wrote:I only ask about the XMBC because I like the ability to control it using my Wifi Smartphone with an app. Can you do the same in Openelec ? This is also why I am wanting to put both onto the 16g Sd Card
You should be able to do the same in openelec.
Posted: Thu Sep 11, 2014 8:03 pm
by Des804
Ok because the App you can was for xmbc I can always try and see.
Posted: Fri Sep 12, 2014 4:13 pm
by AndrewS
Des804 wrote:Ok I don't know if Noobs has Openelec as an option
See the "What's Included" part of http://www.raspberrypi.org/documentatio ... n/noobs.md :)
Posted: Fri Sep 12, 2014 11:38 pm
by Des804
I looked into it and it looks like Yatse will work on it.
