Mettauk
Hard wiring a B+
Fri Aug 22, 2014 1:30 pm
The problem is a micro USB connector sticks out way to far! Even a right angled one! Removing the outer casing of the USB connector leaves some very fragile wiring.
I want to hard wire a B+ board without bypassing protection.
I thought about wiring to PP3 and PP7 but really not sure??
As humans we have been the same for a very very long time, technology changes how we do... not who we are as people.
mahjongg
Re: Hard wiring a B+
Fri Aug 22, 2014 3:22 pm
No, PP7 is wired after the fuse!
AndrewS
Fri Aug 22, 2014 3:29 pm
Possibly you'd need to power via the GPIO header, but add your own "protection" ?
https://github.com/raspberrypi/hats/blo ... pio-header
mahjongg
Fri Aug 22, 2014 5:34 pm
PP1 and PP2 are 5V from the micro_USB before the fuse!
Mettauk
Fri Aug 22, 2014 8:57 pm
mahjongg wrote:PP1 and PP2 are 5V from the micro_USB before the fuse!
Great, thanks, I'll try that as it seems the simplest way.
