mighty69
real-time data
Wed Aug 13, 2014 3:39 pm
I'm using a gyroscope for a robotics project. I found a library that generates a sensor output in degrees per second with an included test script. if i run the test script i can get real-time data from the sensor, but when i import the library into my code, i can only seem to get an initial read. Then as my function iterates, it simply repeats the initial value. I'd like to be able see real-time change similar to the test script. suggestions?
joan
Re: real-time data
Wed Aug 13, 2014 3:41 pm
Examine the test script to see what you are doing wrong.
mighty69
Re: real-time data
Wed Aug 13, 2014 3:55 pm
i'm pretty new to python and programming. I thought that's what i had done, but i guess I'm not quite there.
mighty69
Re: real-time data
Wed Aug 13, 2014 6:09 pm
when i run the test program without moving my model I get the same data results that my program generates. The difference is that when i move the model around while running the test program the results change, but this is not the case during my program run. I am mistaken in calling it a test program; it's actually and included test class.
mighty69
Re: real-time data
Wed Aug 13, 2014 6:17 pm
I was able to confirm that the output datatype is, in fact, a float type in both cases, but for some reason i'm still having trouble. I essentially copy and pasted the code from the test class. still not sure what the issue is.
joan
Re: real-time data
Wed Aug 13, 2014 6:51 pm
Without visibility of the code it's going to be hard to make useful suggestions.
mighty69
Re: real-time data
Wed Aug 13, 2014 8:49 pm
My code is here,
Lines 22-25 are the initial call and 75 -78 i think are the references i'm talking about:
import os
import math
from Adafruit_I2C import Adafruit_I2C
from Adafruit_L3GD20 import *
from Adafruit_LSM303DLHC import *
from Adafruit_PWM_Servo_Driver import PWM
from servo_actuator import ServoActuator
import scipy
import numpy as np
from numpy import *
import time
from datetime import datetime, date, timedelta
#import gpsdata as gps
#accelerometer
lsm = LSM303DLHC(0x19, 0x1E, False)
lsm.setTempEnabled(True)
acc = lsm.readAccelerationsG()
heading = lsm.readMagneticHeading()
#gyroscope
l3g = L3GD20(0x6b, False)
gyro = l3g.readDps()
#servo motors
pwm = PWM(0x40, debug=True)
pwm.setPWMFreq(60)
def sub(a,b):
    return b-a
vecsub = vectorize(sub)
def AccelInput(accel,t):
	tsq = t**2
	G = 9.8
	return (G*accel*tsq)/2
def Velocity(a,t,v):
	G = 9.8
	return (G*a*t)+v
def prevelocity(p1,p2,t):
	if t < 2:
		return 0.0
	else:
		return (p2-p1)/t
def AngleRads(t,gyr):
	convert = t*math.pi/180
	return gyr*convert
def TerminalV(t,a,v):
	G = 9.8
	return t*(a*G)+v
count = 0
DeltaT = 1
class InitialCondition:
	#From GPS, find initial position (Start/Launch).  GPS output type = decimal coordinates.
	"""pos1 = gps.lat
	pos2 = gps.long
	pos3 = 0.0"""
	x=y=z = 0.0
	print('DESTINATION:')
	print("x'=10.00, y'=7.50, z'=16.09")
	pos4=10.00
	pos5=7.50
	pos6=16.09
	print('START (T=0):')
	print('x=0, y=0, z=0')
	boat = array([x, y, z])
	destination = array([pos4, pos5, pos6])
	Roll = gyro.x
	Pitch = gyro.y
	Yaw = gyro.z
	print'Launch orientation is:', (Roll, Pitch, Yaw)
	print'Desired impact orientation: (5, 6, 7)'
	launch = array([Roll, Pitch, Yaw])
	impact = array([5, 6, 7])
	print'Vector from Launch to Destination is:', vecsub(boat, destination)
	print'Rotation from Launch to Impact is:', vecsub(launch, impact)
	print("Ready to launch.")
	print'Heading:', heading
count = count +1
IC = InitialCondition
timelapsed = float(DeltaT * count)
class CurrentCondition:
	if timelapsed == DeltaT:
		previousx = IC.x
		previousy = IC.y
		previousz = IC.z
		currentx = previousx + AccelInput(acc.x, timelapsed)
		currenty = previousy + AccelInput(acc.y, timelapsed)
		elevation = previousz + AccelInput(acc.z, timelapsed)
		previousx = currentx
		previousy = currenty
		previousz = elevation
		position = array([currentx, currenty, elevation])
	else:
		currentx = IC.x + (previousx - IC.x) + AccelInput(acc.x, timelapsed)
		currenty = IC.y + (previousy - IC.y) + AccelInput(acc.y, timelapsed)
		elevation = IC.z + (previousz - IC.z) + AccelInput(acc.z, timelapsed)
count = count + 1
CC = CurrentCondition
joan
Re: real-time data
Wed Aug 13, 2014 9:05 pm
The line
reads the gyro device and assigns the reading to a variable called gyro. Subsequently you refer to the variable (gyro) without re-reading the device. You need to repeat the line gyro = l3g.readDps() when you want a new reading.
mighty69
Re: real-time data
Wed Aug 13, 2014 9:20 pm
That's what i've gathered from others as well. I put that line in the InitialCondition class and then again in the CurrentCondition class which is the one that repeats, but i'm still running into the same wall.
import os
import math
import scipy
import numpy as np
from numpy import *
import time
#servo motors
pwm.setPWMFreq(60)
def sub(a,b):
    return b-a
	tsq = t**2
	G = 9.8
	G = 9.8
	return (G*a*t)+v
	if t < 2:
		return 0.0
	else:
		return (p2-p1)/t
	return gyr*convert
	G = 9.8
	return t*(a*G)+v
count = 0
DeltaT = 1
	#accelerometer
	#gyroscope
	"""pos1 = gps.lat
	pos2 = gps.long
	pos3 = 0.0"""
	x=y=z = 0.0
	pos4=10.00
	pos5=7.50
	pos6=16.09
	Roll = gyro.x
	Pitch = gyro.y
	Yaw = gyro.z
count = count +1
	#accelerometer
	#gyroscope
		previousx = IC.x
		previousy = IC.y
		previousz = IC.z
		count = count + 1
	else:
		count = count + 1
class TransitAnalysis:
   print("Launch.")
	#gyroscope
	while (True):
		time.sleep(1)
		if CC.acc.x < 0.1:
			CC.acc.x = 0.000
		if CC.acc.y < 0.1:
			CC.acc.y = 0.000
		"""if gyro.x - IC.Roll > 0:
			VX = math.cos(AngleRads(DeltaT, gyro.y)) * (Velocity(acc.x,DeltaT,vx))
		if gyro.y - IC.Pitch > 0:
			VY = math.cos(AngleRads(DeltaT, gyro.y)) * (Velocity(acc.y,DeltaT,vy))
		if gyro.z - IC.Yaw > 0:
			FallVel = math.cos(AngleRads(DeltaT, gyro.z)) *(Vprev(z, previousz, timelapsed))
		currentx = AccPos(acc.x, DeltaT, VX, previousx)
		currenty = AccPos(acc.y, DeltaT, VY, previousy)
		elevation = Vprev(DeltaT, previousz, pos3) + previousz"""
		CurrentRoll = AngleRads(DeltaT, CC.gyro.x)
		CurrentPitch = AngleRads(DeltaT, CC.gyro.y)
		CurrentYaw = AngleRads(DeltaT, CC.gyro.z)
		CurrentO = array([CC.gyro.x, CC.gyro.y, CC.gyro.z])
		print'Position:', CC.position
		print'Vector from Position to Destination is:', vecsub(CC.position, IC.destination)
		print'Current orientation, Gyro X: %8.3f dps Y: %8.3f dps Z: %8.3f dps' % (CC.gyro.x, CC.gyro.y, CC.gyro.z)
		print'Rotation from Current to Impact is:', vecsub(CurrentO, IC.impact)
		print'Heading:', CC.heading
		"""if TerminalV(DeltaT, CC.acc.z, FallVel) > 19.5:
			print "That's all she's got Captain."	"""
I'm guessing i have to call it during the TransitAnalysis class as well?
