pi@raspberrypi ~ $ ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:75:d5:b2
inet addr:44.236.212.202 Bcast:49.236.212.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2070 errors:0 dropped:0 overruns:0 frame:0
TX packets:684 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:415744 (406.0 KiB) TX bytes:105925 (103.4 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:108 errors:0 dropped:0 overruns:0 frame:0
TX packets:108 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:8680 (8.4 KiB) TX bytes:8680 (8.4 KiB)
mon.wlan0 Link encap:UNSPEC HWaddr F8-1A-67-0B-E2-97-00-00-00-00-00-00-00-00-00-00
RX packets:5652 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1900818 (1.8 MiB) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr f8:1a:67:0b:e2:97
inet addr:192.168.42.1 Bcast:192.168.42.255 Mask:255.255.255.0
RX packets:2226 errors:0 dropped:0 overruns:0 frame:0
TX packets:3007 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:295232 (288.3 KiB) TX bytes:730913 (713.7 KiB)
pi@raspberrypi ~ $ ip route
default via 49.236.212.1 dev eth0
49.236.212.0/24 dev eth0 proto kernel scope link src 44.236.212.202
192.168.42.0/24 dev wlan0 proto kernel scope link src 192.168.42.1
pi@raspberrypi ~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet static
address 44.236.212.202
netmask 255.255.255.0
gateway 44.236.212.1
dns-nameservers 201.94.65.2 201.94.65.3
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.42.1
gateway 192.168.1.1
pre-up iptables-restore < /etc/iptables.ipv4.nat
#iface wlan0 inet manual
#wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
#iface default inet dhcp
pi@raspberrypi ~ $ cat /etc/hostapd/hostapd.conf
interface=wlan0
driver=nl80211
#driver=rtl871xdrv
ssid=RPI
hw_mode=g
channel=11
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=samsung
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
#wpa_ptk_rekey=600
pi@raspberrypi ~ $ cat /etc/resolv.conf
#nameserver 192.168.0.1
#nameserver 192.168..1
pi@raspberrypi ~ $ ping -c3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_req=1 ttl=58 time=78.5 ms
64 bytes from 8.8.8.8: icmp_req=2 ttl=58 time=78.3 ms
64 bytes from 8.8.8.8: icmp_req=3 ttl=58 time=78.3 ms
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 78.335/78.421/78.537/0.085 ms
pi@raspberrypi ~ $ ping -c3 google.com
ping: unknown host google.com
