SirNight
Does B+ resistant against SD Card corruption ?
Fri Jul 18, 2014 1:13 pm
Hello All,
We do have a Raspberry Pi Type B Farm for a specific purpose application. There are currently 650 Raspis..
As I am working on a high number of computer nodes, SD Card corruption becomes pain in the neck..
I use Kingston SD10V/8GB which is listed on Compatible SD & SDHC Cards for Raspi.
All firmwares & softwares are up to date.
My question is: Does Raspberry Pi B+ resistant against SD Card corruption ?
Also What can I do with my current hardware...
Thanks,
redhawk
Re: Does B+ resistant against SD Card corruption & Power los
Fri Jul 18, 2014 1:49 pm
In terms of data corruption protection against power loss there is no difference between the Model B+ and B.
If you want to protect your Pi from loss of power then use a UPS / battery backup device.
Richard S.
SirNight
Fri Jul 18, 2014 1:53 pm
redhawk wrote:In terms of data corruption protection against power loss there is no difference between the Model B+ and B.
Richard S.
Hi Richard,
Obviously I have UPS for that number of Raspi.. I asked the power loss for making the topic useful for everyone.
My main issue is SD Card corruption. "sudo halt" nicely shutdowns.. No reboot..
mahjongg
Fri Jul 18, 2014 3:08 pm
Nothing will protect against power loss at just the wrong moment when using SD-Cards, (for example if you remove power at the exact moment the card is doing "Wear leveling" it will cause corruptions) , also SD-cards were never designed to be a full HD replacement, like SSD's are. They can and will go bad, especially ones that use a cheap simple and primitive flash controller.
RaTTuS
Re: Does B+ resistant against SD Card corruption ?
Fri Jul 18, 2014 3:28 pm
never shut down ;-p
I've not had any corruption in the last 12months - what are you doing to them ?
how much writing do they get ?
what is being run on them ?
Covfefe
rln
Fri Jul 18, 2014 5:36 pm
SirNight wrote:Hello All,
Hi
There are are a number of preventive actions to minimize the SD card wear:
  • Use a "read only" operatingsystem, that is, one that never writes to the SD-card during normal operation.
  • Try another filesystem, such as f2fs which was made for flash devices.
  • Increase the SD-card capacity. The bigger the better for spreading out the wear.
  • Modify your application to store data on a network server instead of in the SD-card. Resort to the SD-card only when the power is failing (the UPS can send an alarm) or when the network is down.
My project Nard SDK http://www.arbetsmyra.dyndns.org/nard/ can handle the first two issues for you (but there are others as well, just search this forum). The remaining you need to adapt to your particular project.
/Ronny
Author of the robust Nard distro http://www.nard.se
Fri Jul 18, 2014 6:59 pm
It does sound more like SD cards wearing out than corruption, so see previous post.
Just me being nosey, but controlling a bitcoin farm?
Please direct all questions to the forum, I do not do support via PM.
RaTTuS
Sat Jul 19, 2014 7:11 am
jamesh wrote:It does sound more like SD cards wearing out than corruption, so see previous post.
aha Dave is that you
Covfefe
Jim JKla
Sat Jul 19, 2014 7:31 am
If and it looks like you are running loads of SD then I suggest you watch this video
Link to Video
This video does get a little heavy in places but it does explain some of the flakieness about some SD cards and the abundance of fakes out there.
SirNight
Sat Jul 19, 2014 9:48 am
Jim JKla Thanks for the video link. Long but good to know.
Ronny Nilsson Thanks for the recommendations. I 've checked your work, and I will give a go with Nard SDK.. Let's see if we can implement it on our project. Also, I will keep your Donationware notice on my mind.
jamesh So James, you think my SD cards are not reliable or somehow wearing out easily. It there any testing tool or sth like this to prove it? Well, yes, kind of a bitcoin farm.
Sat Jul 19, 2014 10:34 am
SirNight wrote: Jim JKla Thanks for the video link. Long but good to know.
SD cards have a finite life, less than that of HD's for example, since each bit has a limited read/write/erase cycle. There is firmware in the card to do wear levelling, but some are better than others. SO the best bet is to reduce the amount of writing that you do to the card, as I think it quite difficult to determine which cards are better or worse at wear levelling.
