Expand root partitition on a rasbian minimal image
Posted: Thu Jun 26, 2014 8:43 pm
With raspi-config I obtain this error:
Disk /dev/mmcblk0: 1948 MB, 1948254208 bytes
4 heads, 16 sectors/track, 59456 cylinders, total 3805184 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00027aa3
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 2048 104447 51200 b W95 FAT32
/dev/mmcblk0p2 104448 1742847 819200 83 Linux
/dev/mmcblk0p3 1742848 1945599 101376 82 Linux swap / Solaris
Command (m for help): The partition table has been altered!
Calling ioctl() to re-read partition table.
WARNING: Re-reading the partition table failed with error 16: Dispositivo o risorsa occupata.
The kernel still uses the old table. The new table will be used at
the next reboot or after you run partprobe(8) or kpartx(8)
Syncing disks.
update-rc.d: using dependency based boot sequencing
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match resize2fs_once Default-Start values (2 3 4 5 S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match resize2fs_once Default-Stop values (none)
root@raspberrypi:~#
How can I do to expant the partitition?
Syncing disks.
root@raspberrypi:~#
