DougieLawson wrote:CJHeiser wrote:... if you plan on overclocking it you should look into getting a heat-sink ...
Er, why? The CPU will automatically throttle back at 85 degrees.
A heatsink MIGHT mean the temperature stays below 85 so the device never throttles. If you are in a case, with no airflow in a hot ambient environment.
But, pegging the CPU at 100% doesn't produce much heat (pegging the GPU at 100% produces much more), so a heatsink will likely be completely unnecessary for that use case.
