fvdw
fvdw-sl NAS firmware available for raspberry 1 2 3 4
Sun Jun 15, 2014 9:41 pm
Hi community the last years me and my friend developed a NAS firmware that runs on lacie devices.
Recently we tested if it could run as well on the raspberry b.
The test have been succesfull and there is now a first version of this firmware availble for the raspberry b model
Basically the firmware transforms your raspberry in a full blown NAS with lot..lots of features.
The firmware has a web interface and has a lot of features like unlimited number of users and shared folder, it comes with samba FTP (also secured), NFS files servers, ssh server, vpn server, several mediaservers like twonkymedia, mediatomb, minidlna, logitech media server, webtools like btsync, web explorer, webDav, downloaders like transmission, nzbget, MLdonkey, wget, torrentflux, backup via rsync and even a rsync servers, a task scheduler and more...and it is free.
If you are interested you can check it out on http://plugout.net
It is available as disk image that you need to write to the SD card. As the SD card has limited capacity and is not suitable for lots of IO operations you can use USB disk to stored your data and define shared folders.
Even for people not so experienced in Linux it is easy to use and install. Just write the provided disk image to an SD card with minimum capacity of 4 GB put it in your raspberry and off you go
fvdw
Re: fvdw-sl NAS firmware now available for raspberry b
Fri Jun 27, 2014 11:02 pm
There have been several download so far, I would appreciate some feedabck and read about your experiences to see if any optimization is required ?
Elnef
Sat Jun 28, 2014 11:46 am
I knew about your project yesterday. And I have installed in my Pi today and it´s working perfectly.
It´s really awesome. One complete NAS in my Pi. :shock: :shock:
My Raspi is a Rev B with 256 MB, and web interfaces works fast.
I have tested:
- Sharing by SAMBA my usb disk (500 GB EXT4). OK
- Sharing by FTP my usb disk (500 GB EXT4). OK
- Manage users with Total Access one and Read Only one.
I have a question. Is it possible to download from premium servers like Uploaded or Mega? I only see torrent options. I use PyLoad for this use in my Pi.
EDIT: What port I have to open to access web interfaces from internet?
fvdw
Sun Jun 29, 2014 1:27 pm
I don't know Pyload myself but it seems to be a Pyhton application (correct).
Pyhton can be installed as addon to the firmware, see download section on plugout (sub forum addons).
Pyload isn't integrated in the webinterface
About access from internet. This depends form your LAN setup.
I assume the raspberry is behind a router. In that case you need to use port forwarding in your router to forward ports on internet side of your router to the raspberry. In principle you can forward any port you like but be aware of opening security holes. The webinterface of the fvdw-sl firmware can run in normal http mode port and secure mode https. It uses the standard ports for that
For the other server you can see in the webinterface which ports are used.
GarethD
Sat Jul 12, 2014 9:42 am
Excellent nas software, just works straight off when I installed it on a pi model B, not only that , but an old LaCie EDMini v2 I had years ago has been revitalised by installing a version made for it.
trojjanhorse
Sat Aug 02, 2014 6:04 am
Your forum won't allow me to use any of my emails to register.
The e-mail address you entered is not allowed to be used.
fvdw
Sat Aug 02, 2014 3:19 pm
this can be because we got annoyed by many spammers using addresses like gmail
Send an e-mail to the admin of plugout with the e-mail you want to use and we can make an exception
sorry for this inconvienience
trojjanhorse
Sat Aug 02, 2014 10:20 pm
Thanks for the quick response. I created an account by the alias trojjanhorse but I do not permission to open any threads aside from the general announcements. I can see more threads when I log out. This is the message I get when I attempt to enter the download thread when logged in via the URL.
You are not authorised to read this forum.
fvdw
Sat Aug 02, 2014 10:52 pm
thats the result of another spammers check, you ip info has some suspicious information. I will enable your account trusting you are not a spammer
default_user8
Wed Aug 27, 2014 7:23 pm
I registered for your forum, but cant access the downloads section.
Two heads are better than one, unless one's a goat head.
fvdw
Wed Aug 27, 2014 8:45 pm
I have sent you an e-mail and activated your account
ravecrocker
Fri Sep 12, 2014 5:00 am
i registered on your forum roo but cant access anything same username
fvdw
Fri Sep 12, 2014 7:38 pm
you account needed check as it didn't pass the anti-spammers checks, we activated it so you should be able now to access the forum normally
fvdw
Wed Dec 31, 2014 9:52 am
We released version 16-0 of the fvdw-sl firmware (nas)
plugout forum
The upgrade and first install,is in the download section of the forum. You must register to access that part of the forum
To get some idea on the firmware use this link explore fvdw-sl firmware
Amongst other s it now has support for MAC devices (afp server) and support for raid.
The raid array must be made manually in version 16-0, in version 16-1 this will be possible via the web interface
Release notes fvdw-sl 16.0 30 december 2014:
16.0.1 upgrades
- dropbear 2014.63
- minidlna 1.1.3
- e2fsprogs (fs tools) version 1.42.11
- new kernel linux 3.14.2 for nwsp, cloudbox, 5big2, 2big2, isp2 (all kirkwood devices) and 2big1.
- bash 4.3.0.1
16.0.2 new features
- support for raspberry B2, a fvdw-sl firmware is now also available for raspberry Pi model b
- for all nas (feature previously added for Raspberry Pi model b), select how the USB partitions are mounted: external share or internal disk
- support for MAC pc's, afp server for Mac users, integrated in the firmware
- added: afp client tools version 0.8.1
- move a share between two volumes
- select the volume for the technical shares and not basically the disk sda (only for NAS with several internal disks)
- proxy gateway for media servers, btsync, p2p servers and redirections toward the fvdw-sl web interface of other nas
- manage custom shell commands (alias) via the fvdw-sl web interface
- new main setup menu
- support for editing language files and exporting them for contributions
- support for Plex mediaserver
- support for raid, partial implementation : raid devices must be built manually (shell commands) but after creating, they can be used fully with the other firmware features. See the related raid tutorials posted on the board, to build a raid device. In the web interface, create and manage raid devices will be available in version 16.1
- added: zip full version 3.0
- mail, enlarge authorized characters list for the password and better support with gmail account.
- Transmission Client, authentication settings can be changed.
- Safety, uses stronger hash for passwords encryption with http protocol
- Firmware update, better control of potential errors
- Leds management for several devices
16.0.3 bug fixes
- rspb2, samba server hanged when transferring larger files
- NFS server, can not export any USB folder with the additional export file
- USB-extras, wrong evaluation of the free partition size
- Minidlna, can not set a custom serial number in its setup menu
- webdav, admin-nas password not updated in some conf files after changing it in the web-interface
- Apache server, ssl cache files not created after restarting the web server
- Firmware update, fixed timeout issue with Firefox, version>28
- Schedule servers, missing jobs for nzbget and no output in the cron log if the debug mode is disabled(new 10dec)
- Language, the web-interface failed to load some menus if you used an unsupported language (Italian; Danish;...)(new 11dec)
- several minor cosmetic bugs in the Web interface...
- shell schock vulnerability bash command shell, as far as possible
tb-av
Sun Jan 04, 2015 6:21 pm
Can someone please tell me how to get registered on the plugout forum. I tried a gmail address which I prefer and it failed as noted above. So then I tried a Comcast address which it said was not real. Then I looked for a way to mail admin as mentioned above. then I registered here in hopes to contact fvdw but still no means to do so.
Whom may I email to join?
fvdw
Mon Jan 05, 2015 7:31 pm
gmail address are by default on the blacl list on our forum due to spammers.
I added yours to the exemption list so you should be able to register now
Geordie1973
Fri Jan 09, 2015 1:23 pm
Hi your system is blocking my e-mail address too so I can't register. Could you grant me access ?
fvdw
Fri Jan 09, 2015 8:07 pm
Geordie1973
Fri Jan 09, 2015 11:31 pm
Thanks, yes have registered and downloaded the files. Will have a play over the weekend.
hawaza
Sat Jan 10, 2015 11:38 pm
I really would like to give this a whirl but i can't register with any of the email addresses i have. Tried registering with the same username as this one. I've already emailed the admin but since it is obviously blacklisted i'm not sure it will get through.
PeterBij
Tue Feb 17, 2015 11:27 pm
Hello FvdW
Does this media server on a Raspberry only work with a LaCie disk, or can I connect any make of harddisk to the server?
kind regards
Peter
fvdw
Wed Feb 18, 2015 7:50 pm
It works with any hard disk.
netcompsys
Tue Feb 24, 2015 12:35 pm
I too would like to use this but I am unable to register on plugout.net due to my email address being black listed
This is the first time in the 15 years I have been using this address that this has happened, must be a very select group on your forum !
Please white list my address edited - [email protected]
thanks
kevin
edit -
Registration working now Thanks
fvdw
Tue Feb 24, 2015 7:57 pm
it is added as exception, all *.co.uk are black listed, you don't want to know how frustrating it is to keep the forum free from spammers and their posts
