nerd7473
Desktop wallpaper not changing in raspbian wheezy
Thu Jun 05, 2014 3:34 pm
Here is my problem, I downloaded the Ubuntu 14.04 wallpaper for my Pi and I couldn't change my wallpaper so I deleted the wallpaper and now it change...
I tried this but it didn't work:
sudo pcmanfm --desktop-pref
nerd7473
klricks
Re: Desktop wallpaper not changing in raspbian wheezy
Fri Jun 06, 2014 12:59 pm
nerd7473 wrote:Here is my problem, I downloaded the Ubuntu 14.04 wallpaper for my Pi and I couldn't change my wallpaper so I deleted the wallpaper and now it change...
Do not use sudo with the above command and it will work.
-OR-
Just right click anywhere on the screen and select [Desktop Preferences] then select [Wallpaper]
A file manager will appear where you can select the path and filemame of your background image.
The default raspberry pi logo file is deskop-background located in /etc/alternatives
Be sure in [wallpaper mode: fill with background color] is NOT selected.
If you don't have [Desktop Preferences] in the right click menu then do:
click the advanced tab and un select the only option there.
