My Raspberry Pi won't work
Posted: Thu Jun 05, 2014 11:57 am
by Redadil
I went through everything in the instructions. First, I connected it to my television, then I put my 16 GB SD card in, next I put my mouse and keyboard in, after that I plugged the power cable in. The red light is on but the green light is not, the picture is not coming on the television, but it's definitely on. I do not know what to do!!
Re: My Raspberry Pi won't work
Posted: Thu Jun 05, 2014 12:04 pm
by RaTTuS
what is on the SD card
can you look at it in a windows machine [or mac]
Posted: Thu Jun 05, 2014 12:09 pm
by Redadil
There are quite a few pictures, Noobs and Raspian
Posted: Thu Jun 05, 2014 12:14 pm
by Redadil
There are quite a 269 pictures and videos, Noobs and Raspian I mean
Posted: Thu Jun 05, 2014 12:45 pm
by RaTTuS
I have very little experience with noobs
I take it you've done all this
http://www.raspberrypi.org/help/noobs-setup/
what TV connection , what actually is connected ?
where in the world are you
what power supply have you got
Posted: Thu Jun 05, 2014 1:42 pm
by MrEngman
So what have you installed? NOOBS? or Rasbian? You don't make it clear at all. Or did you install NOOBS and install Rasbian from the menu of OS to install?
If you view the SD card on a windows machine an SD card with NOOBS correctly installed should look like this.
MrEngman
Posted: Thu Jun 05, 2014 4:29 pm
by hampi
MrEngman wrote:So what have you installed? NOOBS? or Rasbian?
Sounds like the initial reading of the SD card fails and thus no boot whatever the RPi system is on the SD card.
