Wed Jun 04, 2014 4:49 pm
More-or-less correct.
I do have some concerns, however. The major one is that care is needed in the lay-out of the components around the LM2576 - OnSemi's datasheet is helpful if a bit daunting.
As regards the inductor value, work your way through the data sheet, or just go for the bigger one.
Assume the Pi needs 750mA @ 5v. At 90% efficiency, that's about 350mA @ 12v, so with 600mA for the motor, 1A is enough though with not much headroom.
Assuming the 24v AC is 50Hz, C14 has to supply all the current between incoming peaks, so ~500mA for 10ms.
From CV=IT with 500mA, 10ms, and 100uF, the capacitor will lose 50v during that time - rather more vthan you have available. I'd use 1000uF instead - or put one right by the bridge, and the 100uF one right by the chip. And don't forget, the incoming AC is 24v RMS, so the peak voltage will be 35v.
And finally, the 1N4002 is a 1A device - I'd be looking at 1N5401 as a 3A device
