Raspberry Pi B power supply limit
Posted: Sun Jun 01, 2014 10:27 am
by foulquesnera
I search for my Bot to offer maximum power ressources to the RaspPi B (with usb-wifi antenna).
I own a old Hand Electric Drill battery delivering 18,5 v.
1) Can I use it, with connection on micro-usb connector ?
2) Or is there an other connection point ?
3) or do I need to regulate this power source ?
Best regards.
Re: Raspberry Pi B power supply limit
Posted: Sun Jun 01, 2014 10:44 am
by riklaunim
Raspberry Pi needs a 5V power supply. Only 5V.
Posted: Sun Jun 01, 2014 10:47 am
by DougieLawson
If you attach 18V5 to your Raspberry Pi you will have a very dead piece of pi that's headed for the recycling.
You'll need to use a voltage regulator to drop 18V5 to 5V0. Don't use a 7805 it will glow red hot with that sort of voltage, you'll want to use a buck converter. http://en.wikipedia.org/wiki/Buck_converter
