GreenPhantom
Some help with a few things
Sat May 31, 2014 11:55 pm
Very quick question,
can anyone provide me some links to help me with:
Software to copy the debian wheezy image to an SD card.
Software to be able to copy over any media/roms to the Pi.
Any software to type in lines of code to the Pi's terminal screen from my PC
Thank you
Re: Some help with a few things
Sun Jun 01, 2014 12:00 am
GreenPhantom wrote: 1. Software to copy the debian wheezy image to an SD card.
2. Software to be able to copy over any media/roms to the Pi.
3. Any software to type in lines of code to the Pi's terminal screen from my PC
1. Assuming you're using Windows then it's Win32DiskImager that you need
2. No idea what that means
3. Assuming you're using Windows then it's PuTTY that you need
FLYFISH TECHNOLOGIES
Sun Jun 01, 2014 12:01 am
GreenPhantom wrote:Software to copy the debian wheezy image to an SD card.
Win32DiskImager
GreenPhantom wrote:Software to be able to copy over any media/roms to the Pi.
USB memory stick ?
GreenPhantom wrote:Any software to type in lines of code to the Pi's terminal screen from my PC
PuTTY.
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
GreenPhantom
Sun Jun 01, 2014 12:04 am
Thank you!
And I'm not sure how i would copy pictures and roms onto the Pi, to use inside debian wheezy
Sun Jun 01, 2014 12:07 am
GreenPhantom wrote:And I'm not sure how i would copy pictures and roms onto the Pi, to use inside debian wheezy
Using shared media (mentioned USB memory stick or network drive, etc.), or by downloading via server (installed either on RasPi or on another computer within internal network or public Internet).
GreenPhantom
Sun Jun 01, 2014 12:13 am
Thank you for the help
Sun Jun 01, 2014 6:15 am
I assume you mean Raspbian Wheezy? There is no point in running the old Debian image (even if it is still available) as it is not optimised for the Pi and runs quite a bit slower. Raspbian has the same software available as Debian.
toxibunny
Sun Jun 01, 2014 9:50 am
mobaxterm is pretty good too, and will let you drag&drop files into your pi, if you have things set up right...
note: I may or may not know what I'm talking about...
MattHawkinsUK
Sun Jun 01, 2014 10:47 am
I use MobaXTerm (http://mobaxterm.mobatek.net/).
It lets you open terminal windows just like Putty ... but it also gives you basic file browser so you can drag-n-drop files from your PC. Plus if you launch some applications they open in separate windows.
You can also configure it to give you a GUI when you run startx. All from your Windows PC. Possible to do using other techniques but I've found this to be the easiest to setup.
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
