lilzz
Do we really need relay to interface with Pi's GPIO?
Sat May 31, 2014 4:59 pm
Is relay a must have? If not , at what condition is it needed?
http://nwazet.com/nwazet-pecan-pi-relays
A relay is nothing more than a switch right?
FLYFISH TECHNOLOGIES
Re: Do we really need relay to interface with Pi's GPIO?
Sat May 31, 2014 5:09 pm
lilzz wrote:Is relay a must have?
No.
There are just few things which are a must have,... air, water, some food and sun come to mind first. ;-)
lilzz wrote:If not , at what condition is it needed?
Typically, when you need to switch high voltage / high current load.
lilzz wrote:A relay is nothing more than a switch right?
Yes. An electronically-controlled switch.
P.S. Google can answer this kind of questions very well...
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
Richard-TX
Sat May 31, 2014 6:33 pm
Relays are used when a "switch" is needed. Since the Pi can only handle ttl loads that makes it a starting point. My rule of thumb is like this:
When switching main voltages a solid state relay is tops. Silent, able to be triggered by the Pi directly, plus UL/CE approved.
When switching lower voltages and/or currents a small relay works. While not silent, the noise level is acceptable.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
