andygturnbull
start up
Fri May 23, 2014 8:30 pm
Hi
I have just bought a raspberry pi starter kit and have connected everything to my television to set up the os.
When I try to use one of the os it says that there is not enough memory to download or start.
am I doing something wrong as the SD card is 4GB and should have more than enough memory space I would of thought that with that I would be able to download all the OS onto it??
Re: start up
Sat May 24, 2014 7:12 am
NOOBS needs an 8GB card as a minimum size.
NOOBS-lite may fit on a 4GB card
The plain Raspbian image will fit on a 4GB card (but needs the Win32DiskImager to copy it on there).
I'll do your homework for you for a suitable fee.
Joe Schmoe
Re: start up
Sat May 24, 2014 9:28 am
… needs the Win32DiskImager to copy it on there).
Not true, of course, as there are many other (better) ways of doing it.
Re: start up
Sun May 25, 2014 10:35 am
Except it is very true for the beginner running windows.
Why do you have to contradict everyone on this forum, do you know how annoying that is?
Joe Schmoe
Re: start up
Sun May 25, 2014 11:15 am
Not everyone - just you. I don't like the way you spread misinformation.
DeeJay
Re: start up
Sun May 25, 2014 11:33 am
Joe Schmoe wrote:Not everyone - just you. I don't like the way you spread misinformation.
No - you do it to me too! Perhaps it would be more productive and acceptable if you gently explained how the information was incorrect and what the real facts are.
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
Burngate
Re: start up
Sun May 25, 2014 12:05 pm
Better?
Starting with a computer running Windows, Win32Diskimager works, and although it's not necessary to use that particular program, any other is unlikely to be "better".
If "better" entails using a computer running Linux, or indeed one running any OS other than Windows, it's only "better" if you already have said computer running Linux or the non-Windows OS
So
could be expanded to
… needs the Win32DiskImager to copy it on there, where "Win32DiskImager" is taken to mean "Win32DiskImager or some other similar program", and "similar" means "has the same functionality when using an appropriate OS").
But it's easier to stick with the original, and assume the reader has at least some intelligence
johndough
Re: start up
Mon May 26, 2014 10:35 am
andygturnbull wrote:Hi
Hi
Did the starter kit come with an SD card pre-loaded?
What/Where did you buy said starter kit.
