Burnsy74
Solid State Relay advice.
Fri May 23, 2014 4:01 am
Just registered and am looking some advice re SSR. I have the sainsmart 8 channel relay at the minute and it works well.
Is there an equivalent Solid State Relay as I need one that will work silently?
http://www.sainsmart.com/8-channel-dc-5 ... logic.html
evilkitty
Re: Solid State Relay advice.
Fri May 23, 2014 10:38 pm
how much voltage/amperage are you working with on the other side of the relay and is it AC or DC
sound dampening a option? or perhaps sound cancellation, not exactly cheap solutions but options none the less
My Pi Server: http://imgur.com/a/6xIUI | Thermostat: http://imgur.com/a/4LVnT
johndough
Sat May 24, 2014 11:43 am
Burnsy74 wrote:Hi,
Hiya
Silent relays are latching relays, they latch and turn off the coil, next time the coil is 'energised' the latch releases. So you only send a latch / unlatch command for about a second.
Large versions of this type are used in hospitals for lighting, the relay does all the hard switching but no coil noise or current usage.
Some info here >>> http://www.azatrax.com/latching-relay-circuits.html
http://www.eeweb.com/blog/extreme_circu ... hing-relay
This is a mechanical system not an electrical self hold circuit.
If in doubt please ask.
Richard-TX
Sat May 24, 2014 12:52 pm
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
