Markus1981
how to shrink rootfs and img file
Mon May 19, 2014 5:35 am
Hi
I made a image with some programs in it for myself , that i want to back up .
How can i make the image smaller ?
I deleted all unneccesary programms from the original raspbian image and installed the programms i need . Here are my two problems :
1.
The used space by the distro is now 1.59 GB but the root fs is about 4GB . how do i shrink that to the amount that is really used ? ( i only know how to expand rootfs)
2.
I used win 32 diskmanager to create a img file , as it is a raw copy of the original 16GB SD card it uses 16 GB on the img file (instead of the 4 GB that the distro uses )
I tried googling but without success
Regards
Markus
ShiftPlusOne
Re: how to shrink rootfs and img file
Mon May 19, 2014 6:06 am
Lots of ways to go about it, but you'll want to use linux to do it. From easiest to hardest:
Use partimage - you won't get a .img file you can simply write back. You will need to use partimage to restore as well.
dd normally, then use shrink_image ( https://github.com/asb/spindle/blob/master/shrink_image ) - You may need to modify the script to work with your distro.
Create a blank image of the required size, partition and format, mount and rsync into it
Shrink the filesystem on the card and only dd up to where you need to
BillStephenson
Mon May 19, 2014 9:15 pm
Here's some instructions and scripts to help with this. They worked for me.
http://www.raspberrypi.org/forums/viewt ... 91&t=58069
