J__
Audio INPUT w/ puredata
Fri Apr 25, 2014 4:02 pm
I run puredata on raspberrypi with satellite ccrma.
I need to use a sound input.
I have a logitech usb to jack audio card, and a creative soundblaster play.
I get a good audio quality when any input is deactivated, but when I try to activate the input the sound gets really glitchy.
dwc_otg.speed=1 doesn't change anything.
any change of the sample rate neither.
Anyone managed to work with an audio input?
Thanks,
J.
redhawk
Re: Audio INPUT w/ puredata
Fri Apr 25, 2014 4:13 pm
Audio capture is a bit screwy at the moment so I suspect you're probably running the 3.10.25+ kernel.
To verify this please run: uname -a and report back the version number.
Updating the kernel version should fix the problem (unless it's broken again) - http://www.raspberrypi.org/forums/viewt ... 28&t=70437
Richard S.
