lilzz
12 bits ADC with 8 channels
Sat Apr 12, 2014 5:03 am
What does it mean that the 12bits ADC has 8 channels? If I read from channel 0 is that going to be enough? Do u need to read all 8 channels? What do I do with 8 results? Taking an average?
ShiftPlusOne
Re: 12 bits ADC with 8 channels
Sat Apr 12, 2014 5:07 am
Yaikes, I removed the duplicates, but there's no need to post the same topic three times. :o
Sat Apr 12, 2014 7:56 am
12bits defines the granularity of the signal depending on the voltage that the ADC is reading.
8 channels means you can read eight unique 12bit values simultaneously.
joan
8 channels typically mean you can read 8 separate voltages, e.g. monitor the level of 8 different batteries by 8 separate wires to the device. Typically you can also configure the channels as 4 differential pairs (I assume for increased accuracy).
Richard-TX
Sun Apr 13, 2014 4:46 am
Most ADCs have a limit to them regarding input voltage. Usually the limit is equal to VDD. In the case of the Rpi, that limit is either 3.3 or 5 volts depending.
Here is a maximum resolution for 8 bit and 12 bit at 3.3 and 5.0 volts
8 bit - 3.3 volts - 0.01299 volts
8 bit - 5.0 volts - 0.01968 volts
12 bit - 3.3 volts - 0.00080 volts
12 bit - 5.0 volts - 0.00122 volts
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
